May 18, 2013, 08:52:44 PM *
Author Topic: 68 455 Rebuild, power guess?  (Read 689 times)
shank0668
« on: February 25, 2012, 08:19:39 PM »
I may be getting an olds 1968 455. The car has "E" heads. The current owner believes it's from a delta 88. The block and heads have been hot tanked and magnafluxed. It is currently bored .030 over, and will need another .030 to clean up. The guides and valve stems are worn. There are two broken valve springs. The crank is also too far gone. At least one rod is bad too.
It comes with a custom cam with these specs.
-----------------Int Exh
Adv Dur --------274 283
Dur@.050------ 230 240 Lobe Sep 110.0
Valve Lift ------.538 .541
I have a few questions. I am looking for just a mild build.
What Crank should I use? A stock crank or aftermarket?
What aftermarket .060 pistons do I use?
Should I go aftermarket rods or reman'd?
Im just wondering what parts to use?
I am wondering if that is a good cam, and will it produce a nice, streetable power, with a rough idle?
Also, what kind of power should I expect?
I'm going to keep the stock heads.
thanks
shank0668
« Reply #1 on: February 26, 2012, 06:37:36 PM »
Lunati VooDoo 60805
    * Advertised Duration (Int/Exh): 284/292
    * Duration @ .050 (Int/Exh): 241/249
    * Gross Valve Lift (Int/Exh): .539/.555
    * LSA/ICL: 110/106
    * Valve Lash (Int/Exh): Hyd/Hyd
    * RPM Range: 2400-6200
  Too much Cam for a 5 speed application?
seac79ta
« Reply #2 on: February 26, 2012, 06:44:33 PM »
Lunati VooDoo 60805
    * LSA/ICL: 110/106
Yes
shank0668
« Reply #3 on: February 26, 2012, 06:52:01 PM »
Lunati VooDoo 60805
    * LSA/ICL: 110/106
Yes
Lol I heard the idle, i like it but i doubt driving would be good, or even decent.
seac79ta
« Reply #4 on: February 26, 2012, 07:04:51 PM »
Lunati VooDoo 60805
    * LSA/ICL: 110/106
Yes
maybe the 60804
shank0668
« Reply #5 on: February 26, 2012, 07:15:56 PM »
Lunati VooDoo 60805
    * LSA/ICL: 110/106
Yes
maybe the 60804
I should just live with it and get a decent idleing cam
shank0668
« Reply #6 on: February 29, 2012, 04:41:41 PM »
Lunati VooDoo 60805
    * LSA/ICL: 110/106
Yes
maybe the 60804
Lunati recommended the 60802
shank0668
« Reply #7 on: April 17, 2012, 06:57:20 PM »
I think I may just go back to stockish.... Find a used 4 speed crank, get 1 or 2 rods replaced.  Maybe a set of .060 forged pistons.
Just a nice cruiser...
I think it should still have a crap ton of torque.
