Good afternoon all. This has been the most annoying engine swap i have ever done. First the timing cover needed heli coils where it meets up with the oil pan. Then the oil pan wouldn't line up with the timing cover. Balance needed extra work to pull onto the eagle crank. Hopefully it pulled all the way down. When i went to install the trans; it would not turn, so it wouldn't spline into the clutch, so i had to tear it apart and put new cover shaft bearings on. Now the trans is waiting to be installed so i can finish everything else. It's been one of those kinds of builds this time.
