May 23, 2013, 06:57:44 AM *
Pages: [1] 2 3
Author Topic: How to install front coil springs without killing yourself!  (Read 32174 times)
JasonD
« on: April 28, 2007, 03:14:53 PM »
Anybody who has ever tried installing coil springs on a car with no engine in it knows that putting them in can be a real challenge due to the fact that there isn't enough weight to hold the front of the car down. Here is how you do it easily and safely.  Cool
#1  PREPARE YOUR WORK AREA
You want your control arms mounted to the frame and swinging freely. You want to have all your ball joints in and ready to go along with the nuts that go to them. You want your steering knuckles clean and ready to mount. You want to have a large chain to use as a safety chain. You will also need a coil spring compressor and a large socket wrench to turn it. Don't forget a floor jack and a pry bar.....and of course, those crazy coil springs. My coil spring compressor was purchased from National Parts Depot under part # 988-1 for $35.
#2   DROP IN THE COMPRESSOR AND MOUNT THE SPRING
A spring compressor usually comes with two ends that have hooks on them. One set of hooks slides freely up and down the long threaded rod and one actually screws onto the threaded rod. You need to remove the hooks that slide freely and set them aside. You want to use the hooks that screw up and down the rod.
Drop the threaded rod down through the upper shock hole in the subframe. Make sure you have a couple stout washers underneath the head of the bolt. Screw the threaded hooks onto the end of the rod.
If you are using the rubber spring isolators, attach them to the top of the spring now with plastic wire ties. Now mount the spring up into the subframe with the spring compressor going down through the center of the spring. Use the hooks to grab onto the spring at the lowest possible point. Make sure the threaded rod is centered in the spring. Make sure that the bottom end of the spring is rotated to the right spot so that when it's compressed it fits into the little pocket in the lower control arm correctly.  Now begin to tighten down the big long bolt just tight enough to hold the spring in. Once the spring is supported, use the safety chain to wrap through the bottom of the spring and around the subframe. This is a safety precaution just in case the spring compressor breaks or some other failure happens. These springs are very dangerous when compressed so do this EVERY time.
#3   COMPRESS THE SPRING
Once your safety chain is hooked up, you can begin to tighten the big threaded rod and compress the spring up into the subframe. Once you have it compressed enough to swing the control arm up high enough, attach the steering knuckle to the lower control arm ball joint. At this point you should slide the floor jack under the lower control arm and use it to hold the control arm tight against the bottom of the spring. Use a pry bar to pry the bottom of the spring into the spring pocket on the lower control arm. It will pry in very easily and pop right into place. Now use the floor jack to jack up the steering knuckle high enough to attach the upper ball joint. Once the ball joint nuts are tight, you can remove the safety chain.
#4 DECOMPRESS SPRING AND ADMIRE WORK
Once your ball joints are all attached and your steering knuckle is in and the safety chain is off, you can take out the floor jack and then loosen up the spring compressor to let the full tension of the spring out on the control arms. The spring compressor rod just pulls out the shock hole and the hooks just fall out the bottom hole. Pat yourself on the back....you got your coil springs in without maiming anybody!  Very Happy
The_Terminator
Guest
« Reply #1 on: April 29, 2007, 08:02:46 AM »
Pure Genius...plain and simple.
Note:  Put this one in the "never gonna be destroyed, burned, maimed, lost, stolen, misplaced or forgotten" archives!!!
500cidstroker
Forum Member
« Reply #2 on: July 29, 2007, 07:30:56 PM »
What brand of internal spring compressor did you use ? I have broken 3 internal ones . and I bought a set of the external ones but the spring will not go up in the frame pocket with them on the outside. I have tried to do it as you have shown and the threaded nut strips out after I get about 2 3/4 inches compressed . I have tried to compress the spring as shown by the tool maker with both coil ends on , and as soon as i get down to around 3 inches it broke . I need to get them compressed down from 16 inches to about 12 1/2 to fit in . The motor is out of the car so I can't use any jack under the a arm method .  I'm starting to wonder if the springs are to stiff.   I purchased them new from Ames and they were made by moog for a 78 with a/c , and with performance suspension (WS6) .The springs are about a half inch longer than the old ones , have the same outside diameter , the same coil thickness .  But the new ones have one extra wrap of coil versus the old .
glhx
« Reply #3 on: September 25, 2007, 09:47:29 PM »
i used the spring compressor from napa and it worked realy well. Thank you for the post. It saved me alot of time and headache. My springs were only compressed down to 14 inchesand pry in the rest of the way.
L8KRFAN
« Reply #4 on: April 03, 2008, 09:33:03 AM »
Great info, but I wish I would have known about this last year when I did the suspension on my 71. Installing the coil springs was by far the most p.i.t.a. part of the install. I did it the old fashion way by compressing the spring with the same spring compressor you have but hoping the spring would not kill me! I also did not have the motor (or any front end sheet metal) in the car so the car would raise if I used the floor jack method.
Again, great post!
Los Angeles, California
1979 Trans Am with Olds 403 Matching Numbers "Red Dragon"
Rob
patience & persistence
« Reply #5 on: April 29, 2008, 08:10:55 PM »
you a pimp 4 this one thnx son  Very Happy
josephdrummerj
Forum Member
« Reply #6 on: June 06, 2008, 08:11:40 PM »
just had to say, great advice! im currently restoring my 1970 lemans sport and was kind of worried about installing the front springs. i was able to rent for free a coil spring compresser (thanks to living in a small town) and installed them just like you said. i did have the motor and trans in the car so that helped with the spindle install, but it still would have worked without it. i was able to get them in by myself, and yes without killing me! thanks for helping us shade tree mechanics and now my car is ready to rock!
Formula400
« Reply #7 on: June 14, 2008, 10:32:57 PM »
Thank you for this.  This was very helpful.
Biff1212
« Reply #8 on: August 23, 2008, 02:47:54 PM »
Thanks for posting this. I'm just starting this job and wondering the best way to attempt it. Great info. Thanks!
Jay
Calgary, AB
1977 4 speed W72
Biff1212
« Reply #9 on: September 09, 2008, 08:28:15 AM »
Great info Jason. I would like to share a tip that I used when I installed my springs. Instead of prying the spring into the lower control arm and using a floor jack, I used a couple of ratchet straps. One was hooked onto one of the lower coils and to the opposite side of the subframe and the other was on the lower control arm to the upper control arm once the spring was in position on the lower control arm. As I compressed the spring I tightened the ratchet strap attached to the spring to keep it inline with the lower control arm. Once the spring was compressed and the ball joints lined up the other strap was tightened to bring everything together. Worked like a charm!
Jay
Calgary, AB
1977 4 speed W72
jcurrieta
The Car is done!!
« Reply #10 on: November 03, 2008, 03:38:27 PM »
Few questions:
how hard is this exact method with the inner and outer fender still on?
also say i didnt use a compressor (my engine is in also) could one use the jack method with a safety chain of course to remove the springs?? Basicly when the lower arm (LCA) is supported and unbolted from the spindle (at the ball joint) does the LCA swing down far enoght to let the spring come out without it being compressed 1st?
'81 Trans Am 6.6L T-top (Y84 recreation) "SOLD"
'96 Trans Am LT1
'99 Dakota 4X4
'93 STS Cadillac
79trans-am
400 swap under way :)
« Reply #11 on: January 06, 2009, 09:24:41 PM »
great info. i have been thinking about lowering my 79 T/A with ratial tuned supention. i was looking at the eibach kit with two front springs that lower it an inch. then just som new shocks out back and blocks of aluminum under the leaf springs to get the rear to sit a little lower also.
and advice or suggestions?
1979 T/A... Olds 403, Red on red w/ gold bird, and American Racing Outlaw 2 wheels--- Future= '73 400 swap w/6x-8 heads 'under way' (long way to go), 15x8 snowflakes (I'm cleaning and re-finishing), Macho T/A inspired silver/red paint-job, along with many other small projects with the car!
sinister76ta
-Christopher-
« Reply #12 on: January 06, 2009, 11:29:17 PM »
I admire the amount of safety used in the pix and this tread. I was no where near as cautious when I did the springs in my 75 and 76, looking back I guess I should have been safer then using a gorilla bar and letting the springs fly(won't even mention the beer). I did however use the correct compression tool. I'm glad to see a safe instructive proceedure on removal and installation of coil springs.
73 Black Formula 400 4 speed
74 Admiralty Blue T/A 455 auto
75 Candy Apple Red Firebird 350 auto
76 Cameo White T/A 400 auto
76 Starlight Black T/A 455 4 speed
76 Sterling Silver T/A 400 4 speed
77 Glacier Blue Esprit 400 4 speed
81 Black Formula
75 Silver Formula parts car
76 Carousel Red T/A parts car
76 Trans Am parts car
78 Skybird parts car  -sold-
JacksTA
« Reply #13 on: April 17, 2009, 07:28:32 PM »
Installed both springs today in under 30 minutes, worked great, thanks for saving me grief. It's unreal how that shaft just fits in that hole, like it was made for it. I also used a plastic washer under the steel washer on the top so it didn't scratch the subframe at all. I did a 69 Camaro a few years back, and I don't think the hole was big enough to do it this way, and man was that rough. Thanks Jason, great stuff.
fixitrht
« Reply #14 on: December 17, 2009, 02:40:13 PM »
I tried it this way just the other day and wow, it was so much easier than the prybar and dual spring compressors... great tip  and use the strap too, just not the small one in the pic... use a big one as these things are under pressure
My cars
77 400 4 SPEED W72 Y81 SE (Driver)
79 Y84 Auto SE non t-top (Collecting Parts)
71 400 4 SPEED FORMULA (Working Restoration)
73 455 4 SPEED TA Brewster (Waiting Restoration)
79 403 (not sure why I got this)
80 455 (daily)
cant talk about the 3 parts cars..
75 Chevy Corvette-- not by choice
Pages: [1] 2 3
