Author Topic: help! r/r rear leaf springs 71 trans am  (Read 1179 times)
27fever
« on: November 04, 2010, 06:43:13 PM »
hi all,ok car is up on jack stands (4), I disconnected the rear sway bar,the shocks,the drive-shaft,removed the t-bolts and the u-bolts and lower rubber pad that attach the leaf spring to the axle,and removed the 3 bolts that attach to the front eyebolt to frame,I think I should have removed rear shackles first but at this point I dont think it matters,my help question is with axle shafts supported also by blocks,there seems to be alot of tension still on the leaf,where should I be jacking or raising axles to make sure leaf is at its relaxed position so I dont kill my self removing ?any step by step? help needed..I was planning to remove the gas tank later to install a new sending unit,should I go ahead and do this now? I hear sometimes the rear shackles bolts are a bitch?
« Last Edit: November 04, 2010, 06:52:12 PM by 27fever »
1blk1
  • '79 WS6 W72 M21
Re: help! r/r rear leaf springs 71 trans am
« Reply #1 on: November 04, 2010, 09:32:06 PM »
you need the diff on a floorjack so you can raise and lower as needed...and yes the tank out of the way makes it much easier
"the more im around people, the more i like my dogs"
“Extinction is the rule. Survival is the exception.” Carl Sagan
« Reply #2 on: November 05, 2010, 12:17:25 AM »
Let the car sit on stands with the diff and springs hanging, unbolt the lower plates, shocks etc, lift the diff with a trolley jack...it will pop off the springs. you can then leave the diff supported by some spare stands and change the springs.
