Author Topic: 4L80e transmission swap  (Read 4576 times)
critter
« on: January 02, 2010, 08:36:48 AM »
It has begun. I'm updating a thread on our club web site with details so, in the interest of not typing it all twice, here's a link.
http://tinyurl.com/yjza523
Re: 4L80e transmission swap
« Reply #1 on: January 02, 2010, 07:44:53 PM »
Nice Chris....using the Shiftworks kit for the shifter detents?
I see the HPP is currently running a three part article on a 4L85E swap into a 74 T/A....very similiar to your points. It seems they gave up on modifying the original crossmember after they cut it out like yours....and fabricated a new crossmember altogether. You might want to use the trans mount tab off a later TH350 crossmember, I believe the 4L80E/85E use a single bolt style rear mount.
Interesting to see it all come together.
critter
« Reply #2 on: January 02, 2010, 08:03:59 PM »
Yes, I'd offered my swap to Tom as a story setup but he already had that on in the pipe. That's where I got the pilot bearing information from that didn't work for me. I'm not sure what the difference is but I've called Tom and left a message. I want to understand it.
That crossmember thing is interesting. I have a 2 bolt mount for the TH400 that bolted right up to the 4L80e despite all the TH350 stuff I've heard. Go figure. Until we get that drive shaft I won't hazard a guess on what we'll end up with. Pinion angle can be critical.
« Reply #3 on: January 03, 2010, 05:02:41 AM »
Probably the converter you're using has been set up for a Pontiac?...the one in the story that needs the pilot bushing is a GMPP lock up converter supplied with the 4L85E
76LQ9TA
« Reply #4 on: January 04, 2010, 09:08:39 AM »
Does the fitting in the trans case for the rear cooling line have the extension on it?  It is needed to help lube the planetaries.  I didn't see it mentioned in your write up.  Sonnax carries this part.  I used the stock 2004 2wd 2500HD trans cooling lines and modified them at the radiator.  For the crossmember I cut off the stock mounting tab and welded it on the opposite side.
81 LQ9 4L80E Trans Am
Two 79 400 4 speed TATA's
96 DCM Impala SS
Aaron91RS
      • team3rdgen.com
« Reply #5 on: January 04, 2010, 11:08:30 AM »
Sweet!
i'm doing a similiar thing(replacing a th400 with a 4l80e, although different engine.)
I took mine all apart in my basement first to add a transgo HD2 kit and fix some weak parts and see which of the 3 tail shafts I had so I got the right yoke.
He's got an early year 4l80e with both cooler lines up front.
« Last Edit: January 04, 2010, 11:10:28 AM by Aaron91RS »
80-Y84 WS6 SE LS1/4L80e
82 C3 LS1/4l60e
91RS-LS1/T56
www.fquick.com/aaron91rs
critter
« Reply #6 on: January 04, 2010, 04:48:22 PM »
What he said regarding the cooler lines. This is a 1997 date tag but a GM Goodwrench replacement transmission that was pulled from a Suburban that was parted out. Both ports are up front.
Leigh, your explination was as good as any I've heard so far. We'll go with it. :)
Thomasmoto
« Reply #7 on: January 04, 2010, 09:09:06 PM »
I'm also considering a OD install on my 79. What is the horsepower/torque limits of the 4L80E?  Do ya'll think this is better than using a T400 and a Gear Vendor unit? I'd really like to use a trans-brake. Is there a trans-brake of any of the Auto-OD units?
1979 W72 WS6 Black on Black
2011 Corvette Grand Sport
David Thomas
critter
« Reply #8 on: January 04, 2010, 09:36:58 PM »
Most folks say a 4L80e will take 500/500 HP/torque.
Gear Vendors is good but when I bought one and tried to fit it I found that you needed to cut the main reinforcing crossmember through the center of the unibody had to be cut and a plate rewelded to replace  it. I was unwilling to do that for two reasons. First, my car is a Super Duty and that kind of major surgery was unthinkable. Second, I questioned whether I was compromising the structural integrity of the car doing it.
