Author Topic: Replacing a 79-81 front clip with a 77-78  (Read 26456 times)
Gallstaff
  • Come get some.
« on: February 26, 2008, 10:41:50 PM »
I've been looking around for Trans Ams in the 9-11k range and the only ones in really good condition I can find in my area are 79's and 80's, but I really dig the 77-78 front ends and I know people have swapped them out before.  How hard is it to replace the front end on a Trans Am?  Are there any guides out there that detail the process?  I found a deal on a 79 not too far from me but if I have to pay someone to replace the front end for me, it might not be worth the cost.
Rick
Re: Replacing a 79-81 front clip with a 77-78
« Reply #1 on: February 26, 2008, 10:57:07 PM »
Before you get too invested in the idea, can you live with having a different rear end -- i.e., mix a 77/78 front end with a 79-81 rear end?  Some people think that combination looks a little strange.  Changing the rear end is a lot bigger deal that the front clip swap because the tail panel and gas tank filler is completely different.  Just something to consider, for what it's worth. :-?
Gallstaff
  • Come get some.
« Reply #2 on: February 26, 2008, 11:24:14 PM »
I don't think I would mind the difference.  I mean, I've seen both rear ends and don't personally think that mixing and matching the fronts with the rears ruins the overall look of the car.  Changing the front would be my main gripe.
Gallstaff
  • Come get some.
« Reply #3 on: February 28, 2008, 06:15:23 PM »
So 28 views and nobody has any idea how difficult/expensive/timely such a procedure would be?  I know people have done it.  Cmon guys, don't be shy  :D
Rick
« Reply #4 on: February 28, 2008, 06:33:21 PM »
Klatt88 has done it most recently.  Lots of other people have changed out the doghouse/hood for a different year, but he's the one to have done it most recently for a 79 ---> 77/78.  He did it after his 79 clone got clobbered in an intersection.
Klatt88
  • DeKalb, Illinois
« Reply #5 on: February 28, 2008, 07:38:23 PM »
oh yeah, we have done it. 79 T/A got owned by a verizon van, front end completely totaled. We replaced the whole front end, but put a 77/78 front end on it. Changing out the front end is not hard, you do need to have the front metal support bar that slips into the bottom part of the nose. As long as you switch out the support bar, then the nose will fit onto your car, you might have to drill new holes in the fender to mount it. Here is a picture of the front support bar.
Hell Bandit
  • It's good ta be a custom painter;)
« Reply #6 on: March 14, 2008, 08:48:54 PM »
Ive had 14 T/A's and work on lot of friends cars . Hell if you live in Toronto i'll Swap it over for you ! there are 8 main bumper bolts 7/16 i think . And four 1/2 on each fender at the nose. feel down each side where the nose meets the fenders.
Oh and you have to splice the 2 front signal lights . They are different from the 79 wiring.
logikfive
« Reply #7 on: March 14, 2008, 09:07:53 PM »
I believe the parking/turn lights will still plug in directly with no problems, however they are a bit different, visually.
'88 Conquest TSi Turbo 2.6L/5-Speed
17" Cobra R's, S16G @22psi, KDM intake, TurboXS RFL BOV, 284 Cam, 3" Exhaust
DDM 55W HID's
'99 Durango 5.9L 4x4
Superchips 3815, R/T Interior, Magnaflow Duals
5" Lift, 33" Kumho MT KL71's DDM 55W HID's, 12" Kicker CompVR's
'78 Trans Am 455
Too much to list.
Hoontastic
« Reply #8 on: April 14, 2008, 05:51:20 PM »
  And here is the Naked 1980 nose support layout for a little compare and contrast.
  I like the hawk eyes better too. But check the 80/81 nose from the side it's nice. And is growing on me.
resutton6236
« Reply #9 on: August 06, 2008, 08:14:01 AM »
Since you mention the rear section of the car , does anyone have any info or pictures of changing the rear section? Because I also can buy a 79 t/a but I want the 77/78 look as well.
Any thoughts
Robert
takid455
« Reply #10 on: August 11, 2008, 09:01:08 AM »
you need to remove and replace the 79 tail panel (area between the 1/4's w/ one from a 74-78 car). this requires drilling out the old spot welds and welding in a new one. rero tail panels are not the greatest AFAIK. new bumper, tailights, gas door and gas tank. the snouts are different.
79' Blue
« Reply #11 on: August 13, 2008, 01:20:04 PM »
i almost did this but i didnt like the tail lights with the nice frnt. end. so i left the 79 frnt. alone. now lookin at his thred made me think..What was i thinkin?
1979 455 Auto Trans Am-Nocturne Blue/Camel Tan
1973 455 4 Speed Trans Am #'s match-Cameo White/Black-Restored
langss
« Reply #12 on: November 02, 2008, 01:13:37 AM »
I want to do the same thing sort of.When my 78 got hit I found a really good deal on an entire 79 front end so I bought it.I would really like to put the correct nose piece on but I dont have all the parts for the 78 since they were destroyed.Just to get the car running I will have to use what I have, but at some point I want to make it right.All the wiring looks the same so I dont think I will have any issues with that.
Hell Bandit
« Reply #13 on: November 02, 2008, 06:37:37 PM »
the wiring does have to be changed for the signal lights in the front or splice in the 77-8 wires. I like having the orignal wiring , dont like to cut and paste wiring . Even though nun of my lights are orignal im making wiring plugs to blend into my old wiring.
langss
« Reply #14 on: November 14, 2008, 09:25:01 PM »
So I know what I am looking for,what is different.The wire harness that came with the front clip I bought seems to have found a new hiding place,so all I have is what is with the car.Thanks in advance.
kboehringer
  • Peachtree City, GA
« Reply #15 on: November 16, 2008, 12:21:05 PM »
Gallstaff,
The front clip is a very easy transition (as all the others have mentioned).  I've done the transformation and am FAIRLY happy with it.   I recall, many years ago, several friends and I all owned pre-'79 T/A's & Formulas.  AT THAT TIME, we felt the only thing good about the design changes for '79 WAS THE TAIL LAMPS.
In addition to the differences mentioned, the Wheel Spoilers, Front Air Dam, and Rear Spoiler are all different.  The '79+ spoilers will not interfere with the '78 clip and create no additional problems.  Personally, I prefer the look of the pre-'79 foilers and will EVENTUALLY replace them.  Although, I believe the '79+ spoilers are much more durable.
In addition to the changes and items the other guys have mentioned, I also changed the rear spoiler to a '78 version as my original '79 had the lower attchment bolts torn out (this is apparently pretty common) and it was in pretty crappy shape.   IMPO, the pre-'79 rear spoiler helps pull the two looks together a little.  Changing the rear spoiler will require welding up the old holes in the body and drilling new mounting holes as the side pieces are NOT a direct bolt-up. The center trunk section IS a direct bolt-up
Sinc.,
Kurt
« Last Edit: November 28, 2008, 07:09:11 AM by kboehringer »
sinister76ta
  • -Christopher-
« Reply #16 on: November 26, 2008, 07:17:25 PM »
I like the 75 radiator support bars on there. I have those on my 76 also. much better then the wimpy 76-81 style.
73 Black Formula 400 4 speed
74 Admiralty Blue T/A 455 auto
75 Candy Apple Red Firebird 350 auto
76 Cameo White T/A 400 auto
76 Starlight Black T/A 455 4 speed
76 Sterling Silver T/A 400 4 speed
77 Glacier Blue Esprit 400 4 speed
81 Black Formula
75 Silver Formula parts car -dead-
76 Carousel Red T/A parts car -sold-
76 Trans Am parts car
78 Skybird parts car  -sold-
tinman
« Reply #17 on: November 29, 2008, 05:04:23 PM »
i just did the swap not hard to do at all.my self i like the 77/78 nose better and i like the 79/81 tail lights better than the 78 and older. just gave it a shot of black to hold it over maybe just maybe i can get the whole thing painted next year......... :)
78 y88 new project
Hell Bandit
« Reply #18 on: December 03, 2008, 07:35:26 PM »
Front is easy. now try the back end !lol. Mine was a pain in the .... well ,lets say it took some time .
EscapeRacing
« Reply #19 on: March 15, 2019, 09:04:55 AM »
Super old thread, but it was hands down the best thread I found when doing my front end swap so I'm just adding some pics here for referece and a few comments.
I too wanted a 77-78 but could not find one that was in my price range and not a rusted mess. Plus I love wrenching and although I have wanted a "Smokely and the Bandit" Trans Am since I was my daughters age (7) and now I'm solidly in my 40's I am not above doing a front end swap to finally get my dream car. Finally, this is not a show car - I drive it to work at least 3 days a week 75 miles round trip. Yes, the purists will hate the car all day long due to the frankenstein front end, but thats fine. To each thier own. You couldnt knock the smile off my face when I drive this car - every time. Even when its not running "perfectly".
I found a front end from a local parts yard - everything was included such as grill, lights, bumper reinforcement, cover, etc. I paid $500 for the whole thing. It was not in perfect shape but a lot less expensive then buying all new parts from one of the vendors. Install took just a few hours and following this thread everything bolted up. The turn signals bulb holders had to be slightly modified but work fine. No wiring issues at all - I did not change one wire out during this install.
« Reply #20 on: March 15, 2019, 10:24:21 AM »
I'm can't quite see but did you swap to the early flares and chin spoiler?
langss
« Reply #21 on: March 15, 2019, 12:57:31 PM »
I know its a an old thread, but I looked at the existing wiring some time ago, and it looks like the wires may be a little short to fit the 79 front end. The side markers are in the same location, so that is not a problem, but the turn signals may be a little short. I think the headlights will reach. I'm a long way from finishing this, but I'm glad it worked out for you.
« Reply #22 on: March 15, 2019, 04:04:31 PM »
To escape racing, Good Job!  Car looks really nice and youre  happy with it. Don't worry what others may say.
« Reply #23 on: March 15, 2019, 06:12:31 PM »
Exactly, you're happy. Got the car you wanted, daughter, life isn't so bad. Enjoy.
EscapeRacing
« Reply #24 on: March 15, 2019, 09:16:09 PM »
No, i left the 79 flares and chin spoiler. Another thing that will really bug some folks but I dig it.
EscapeRacing
« Reply #25 on: March 15, 2019, 09:17:43 PM »
Not sure, I didnt extend any wires though. More than happy to take more pics if anyone needs them. I'm missing one front turn signal housing but the other one worked out fine.
