Author Topic: WFO Larry Navarro's drop base air cleaner  (Read 16266 times)
Thomasmoto
« on: February 26, 2008, 10:49:04 AM »
Well I got my new drop=base air cleaner unit from WFO installed last night and it is as fine a piece as I have ever purchased. Kudos to Larry for such a nice piece.
David Thomas
1979 W72 WS6 Black on Black
2011 Corvette Grand Sport
David Thomas
thefirebirdman
      • The Premier Firebird Trans Am Gallery
Re: WFO Larry Navarro's drop base air cleaner
« Reply #1 on: February 27, 2008, 03:06:02 PM »
What carb/intake combo were you running that you needed to buy the kit? How did it help you out?
Jimmy
www.firebirdgallery.com
1969 GTO 400/400 Gold/Gold
1971 Formula 400/400 Blue/Blue
1973 Trans Am 455/4-Speed White/White
2002 Trans Am WS6/6-Speed Pewter/Charcoal
Thomasmoto
« Reply #2 on: February 28, 2008, 11:44:08 AM »
Carb is a 850 double pumper Holley on a Professional Products Polished Hurricane open plenum intake and there is a 1/2" nitrous plate between them. I had modified my stock air cleaner assembly for the Holley, but the combo was still high enough to keep a little more pressure on the underside of the hood than I cared for. Larry's unit is much more appealing visually and it brought the shaker a little lower so it's not so tight against the hood now.
David
David Thomas
pontiac75
« Reply #3 on: March 15, 2008, 02:57:52 PM »
Any chance you could share some more info on this part? Costs, pics, contact info?? Have you seen the one Butler offers? Compare?
Thanks, Darin
johnsma22
« Reply #4 on: March 15, 2008, 03:59:05 PM »
Thanks, Darin
The one that Butler offers IS the WFO from Larry Navarro.
« Reply #5 on: March 16, 2008, 12:37:07 AM »
I bought my WFO from Butlers.....nicely made, but I can't comment on the fit as I don't need it right now...its for the next engine.
Rick
« Reply #6 on: March 16, 2008, 09:55:00 AM »
That's what we like, Leigh!  Forward thinking! :D :D ;)
john0306
« Reply #7 on: March 16, 2008, 07:14:19 PM »
about how much are the bases. Any info greatly appreciated
johnsma22
« Reply #8 on: March 16, 2008, 07:45:22 PM »
You can the product and pricing for yourself on Butler Performance's Website. Just scroll down about 1/4 of the way down the linked page. There are two versions: WFO-1 for 70-76 style shakers and WFO-2 for 77-79 style shakers. They are both priced the same at $198.
« Reply #9 on: March 24, 2008, 07:54:49 AM »
Rick, when I decided to stop playing around and revised my planned spec on that 455 project to include SD Performance heads and roller cam/rockers etc, I figured it was time to step up to an RPM manifold..either the Edelbrock or preferably the new copy of the RPM thats already trimmed down and has no exhaust crossover....hence why I thought I'd order the WFO...along with some other stuff....like a Canton road-race pan etc.
And now that I decided on the SD heads...I'm thinking about maybe biting hte bullet and going the extra for SD's worked over KRE alloys......build it once - build it right..... :lol:
Thomasmoto
« Reply #10 on: March 26, 2008, 01:32:59 PM »
I'll post some pics soon.
David Thomas
BAN
« Reply #11 on: April 03, 2008, 12:43:13 PM »
Sounds Awesome leigh!!
mate im gonna have to pick your brain next year sometime once i start piecing together this 455 that came with my recent 77, ill have to throw you the parts list and see what you think about the combo. Would love some good advice from a real pontiac engine guy.
Cheers.
« Last Edit: April 03, 2008, 12:44:49 PM by BAN »
77 Pro Street, 454 BBC, 8-71 Dyers, back halfed.
77 455, E headed, roller, 10.5:1 475hp/575lbs
71 T-37, 350.
« Reply #12 on: April 07, 2008, 04:03:39 PM »
lol.....no worries, mate.  :-D
Larry Navarro
« Reply #13 on: June 15, 2008, 08:48:29 AM »
Thomas, thanks for your support and glad you are pleased with the product. Did you ever get a chance for some pics?
Home of the WFO "Hyperforce" shaker assembly
wfotex@att.net
Products available through Butler Performance
79TASEMAN
« Reply #14 on: June 27, 2008, 10:27:59 PM »
Gotta get me one of those.  Very cool product.
mattgp77
  • Guest
« Reply #15 on: June 29, 2008, 10:10:39 PM »
Hey guys, will these bases work with an electric choke edelbrock performer carb? I have a 403 in my car.  :)
Larry Navarro
« Reply #16 on: June 30, 2008, 07:47:07 AM »
No. Electric choke pod protrudes to far from the carb body.
wfotex@att.net
Bubbaz
« Reply #17 on: October 05, 2008, 02:24:42 PM »
Will they work on a (1979) 403 running Performer manifold with stock carb?
1979 Trans AM /403 / Auto
DaveD
« Reply #18 on: October 12, 2008, 08:06:42 PM »
Which base should I use, I have a 78 with a 455 and using a shaker from a 76..
I am using a performer rpm & quadrajet.
Doug
« Reply #19 on: October 13, 2008, 10:08:09 AM »
Would this apply to Q-Jets as well.  Cliff is building my carb now and putting an electric choke on it.  Do I need to go with the old style choke to make it fit?
Larry Navarro
« Reply #20 on: October 14, 2008, 05:53:33 AM »
Use the assembly for '73-'76 models.
wfotex@att.net
Larry Navarro
« Reply #21 on: October 14, 2008, 05:54:51 AM »
No. The Q-jet carbs are fine with the factory chokes.
wfotex@att.net
Larry Navarro
« Reply #22 on: October 14, 2008, 05:55:55 AM »
No. The Q-jet carbs are fine with the electric chokes.
wfotex@att.net
Doug
« Reply #23 on: October 14, 2008, 07:00:05 AM »
Thanks Larry!
1_Bad_Bird
  • '79 T/A - 455 Olds.... can you say TORQUE :)
« Reply #24 on: October 08, 2009, 12:51:19 PM »
Ok, got me all confused here   :lol:  These drop down air bases look to be slicker than duck doo doo^ on a wet dock.. my question.. are they:
1) compatible with a '79 Trans Am's running the Olds 403?.
2) If not, what does it take to adapt them?
Appreciate any help
1_Bad_Bird
