Author Topic: sidepipes  (Read 15871 times)
lawbreaker2
Re: sidepipes
« Reply #40 on: February 01, 2008, 09:35:10 AM »
My brothers 77 with pipes, no longer on the car.
lawbreaker2
Re: sidepipes
« Reply #41 on: February 01, 2008, 09:38:45 AM »
And yes, I have 3rd* burns on my right leg, I got out of my dad vette with pipes and forgot about them, I had a pair of shorts on, to this day, I will NEVER forget about those pipes, when I get out of my car, I always look and tell all, watch the pipes, it's been 30 + years and seem like yesterday. :sad:
xtrme_ta
      • http://www.cardomain.com/id/Xtrmes10
Re: sidepipes
« Reply #42 on: February 02, 2008, 03:39:40 PM »
Let me confuse you some more. Heres a video of mine running. I run Supertrapps on mine.
76 50th Anniversary Edition  Pro Street Trans Am 454 w/ 8.71 Blower, TH400 Full manual w/ reverse valve body. S&W race Cars Super car rear with Strange center section with 4:56 Gears.
Re: sidepipes
« Reply #43 on: February 02, 2008, 04:34:30 PM »
I really like my sidepipes. Gotta be really carefull getting in and out though. Passengers have to be warned getting in and out EVERY time. I wouldn't want them on a daily driver but for what I use my car for they're awesome! Can't wait to get an in car video around a road course, they sound so good there opening it up through corners, wide open down the straights, then downshifting into corners. Every driving instructor I've had in the HPDE events has said how cool it sounds.
79tranny
Re: sidepipes
« Reply #44 on: February 02, 2008, 10:35:43 PM »
never heard of supertapps..
Josh
Re: sidepipes
RENOVATIONS
Re: sidepipes
« Reply #45 on: February 02, 2008, 10:41:48 PM »
Jeff
Current Projects:
______________
1978 Trans Am 400/auto
1970 Camaro 350/auto
1970 'Cuda
xtrme_ta
Re: sidepipes
« Reply #46 on: February 03, 2008, 11:56:31 AM »
Supertrapps are accually one of the best mufflers on the marlet because they are completely tunable. You can add discs to make them louder or take some away to quite them down.
You can also tune them to make the car run richer and leaner. Increase and decrease backpressure.
There expensive but well worth the money if your running a high end motor.
79tranny
Re: sidepipes
« Reply #47 on: February 05, 2008, 11:33:56 AM »
niice
thats awesome.. probably a bit too extreme for my basic engine set up as of right now tho ;)
but i'll keep that set up in mind for the future when i go for a bigger and "bada$$er" (new word ;) ) set up in my t/a
Josh
mark369
Re: sidepipes
« Reply #48 on: February 17, 2008, 06:30:57 PM »
I had some side pipes on my  78  t/a like in reply #7 They where not that loud. Deeper throat noise. they work like glass  packs. I  have them in the rafters of my  garage if you want to  buy them. They connected to the headers with two "C" shaped tubes forming an "S".  They came off when I replaced  a header and it did not point strait back. New angle would not line up.  When they where  on the car it  could NOT go  on a lift  rack at a shop because the joining pipe between the header and sidepipe had to go below the frame rail and I had no cearance.  They  did add attitude  to  the car!
mpeace
Re: sidepipes
« Reply #49 on: February 17, 2008, 09:37:21 PM »
how much?
Re: sidepipes
