Powerplants => LT# & LS# => Topic started by: beatboy77 on September 29, 2017, 09:30:42 AM
Title: LS3 Swap Project And Recommendations?
Post by: beatboy77 on September 29, 2017, 09:30:42 AM
I have a 77 TA and am about to start an LS3 swap in to it. Going with an LS3 with 6L90 Trans from a 2010 Camaro. MY TA still has the original rear end in it. Do you guys recommend a new rear end for this setup?
Josh
Title: Re: LS3 Swap Project And Recommendations?
Post by: jonathonar89 on September 29, 2017, 10:01:35 AM
No, the 8.5 10 bolt in 2nd gen F-Body cars is a good rear end.  With proper modifications, it can handle a lot of power.  I've even read in a book one time, that if you do it up right, it can hold roughly 1000hp.  It's the late model 7.5 10 bolts that are weak.
One of the first things you should do is weld the axle tubes to the center section.  This is usually the first part to break on a 8.5 10 bolt.  The common upgrade for them after that, is switching to 30 spline center section and 30 spline axles...basically what came in later model trucks.
Post by: beatboy77 on September 29, 2017, 11:38:23 AM
Thank You!
I have heard the 6L80 Transmission is quite large and the floor of the TA will need to be modified heavily to fit. Is there another Transmission you recommend to mate with the LS3, which may be a better fit for a 77 TA?
Josh
Post by: jonathonar89 on September 29, 2017, 01:28:46 PM
Thank You!
Josh
Someone on here did the 6 speed auto.  He posted more on Facebook though.  That Trans work for him but the only issue I could possibly see was that the transmission pan hung slightly below the frame.  Most recommend a 4L80E or standard TH400/TH350 for LS engines.   I would try the 4L60E myself but that's me.
Post by: beatboy77 on September 29, 2017, 01:53:30 PM
Thank You!
Josh
Thank You! I am doing the Hotchkis lowering kit, so I think that makes sense.
Josh
Post by: jonathonar89 on September 29, 2017, 03:11:27 PM
Thank You!
Josh
Josh
Hotchkis is decent for bolt-on stuff.  Global West and Pro-Tourin F-Body are some other options for leaf spring setups.
Post by: Old Chicken on September 29, 2017, 08:29:17 PM
You are going to have trouble with that trans, they are huge.  I didn't want to cut up my tunnel so went with an LS1/4l60e out of an 04 GTO for my build.  Half wish I'd gone with the LS3/6060 manual trans combo but in the end the lazy side won out and stayed with the auto.  Going to have it built to hold the expected 500hp the mods will bring (forced injection).  If you use that trans please post some pics of what you did to make it work.
I'm going to have the original rear built with an aftermarket posi unit and probably better axles, cover, etc.  They are very usable with a little work.
Post by: beatboy77 on October 01, 2017, 09:31:54 AM
What is oil pan is recommended for an LS3 swap in to a 77 TA?
Thank You,
Josh
Post by: scarebird on October 01, 2017, 10:59:44 AM
Supposedly the Holley pan is the hot ticket here.  I did an EROD changeover a couple years ago - the stock pan worked fine with minor grinding on the crossmember.  I plan to put a non-EROD crate in my 71 LeMans.
http://forums.maxperformanceinc.com/forums/showthread.php?t=718107&page=4
Lotta little stuff is the issue: radiator, pedal mount, etc.  We make a nice adapter for the pedal:
http://scarebird.com/index.php?route=product/product&path=96&product_id=163
Post by: jonathonar89 on October 01, 2017, 11:28:31 AM
Does your adapter work with the supplied pedal they give you with that erod engine?
Post by: 78TA_In87 on October 01, 2017, 12:53:33 PM
Thank You,
Josh
Oil Pan:
Chevrolet Performance Engine Oil Pans 12628771
https://www.summitracing.com/parts/NAL-12628771
Oli pan pickup:
Chevrolet Performance Oil Pump Pickups 12558251
I have a shop almost done with my 78 erod connect and cruise.  Here's my build thread.  1st page has a parts list (Hope I have it up to date).
http://transamcountry.com/community/index.php?topic=76341.0 (http://transamcountry.com/community/index.php?topic=76341.0)
Post by: scarebird on October 01, 2017, 08:44:30 PM
Yes.
Post by: beatboy77 on October 02, 2017, 06:14:41 AM
Thank You,
Josh
Oil Pan:
Oli pan pickup:
I like the look of that connect and cruise package. I noticed for the trans, it comes with the 4L65E. Does that fit in a 2nd Gen body without having to cut up the floor? Is it the same size as a 4L60E?
Josh
Post by: 78TA_In87 on October 02, 2017, 09:41:53 AM
Thank You,
Josh
Oil Pan:
Oli pan pickup:
Josh
No cutting was required.
I'm not sure if they are the same size, but the 4L65E is the improved version so I am guessing the same or about the same.
Post by: 1981RoadRace on October 02, 2017, 09:55:57 AM
Regarding the rear end, check out my thread. One thing to keep in mind is that the tube are steel and the center housing is iron. They do not weld together very easily. You will need someone who really knows what they are doing to pull this correctly -- there is a very long warm up and cool down process.
I don't have that level of skill or patience, and I ended up tapping and bolting my most recent housing with short grade 10.9 bolts. These were just long enough to go through the housing and tube, but not come in contact with the axle. I used one 12mm bolt on each side, with red lock tight. Works well, and dint require a lot of skill or patience. The housing has to be completely disassembled and cleaned before and after (you'd have to do the same for welding anyway).
I also put moser 7900fm axle ends on my rear diff, which eliminates the c-clips and converts the axle design to a ford style bolt in.
Post by: beatboy77 on October 03, 2017, 03:20:35 PM
Just wanted to update that I ended up going with an LS3 crate engine from Jegs and a rebuilt 4L60 trans from Monster. Also got a lot of the parts from Muscle Rods. I will keep you updated as we progress through the build.
Josh
Post by: scarebird on October 03, 2017, 04:41:46 PM
Just wanted to update that I ended up going with an LS3 crate engine from Jegs ...
Josh
Which one?  I am torn between the EROD 6.2 and the base non-emission version for my 71.
Post by: beatboy77 on October 03, 2017, 05:18:03 PM
Josh
This one here
http://www.jegs.com/i/Chevrolet-Performance/809/19301326/10002/-1
Josh
Post by: scarebird on October 03, 2017, 08:07:09 PM
mmnnh.
Post by: Old Chicken on October 03, 2017, 09:01:27 PM
I'm using the F body pan, seems like that's what most of the Camaro second gen guys were using. You can get the whole kit on eBay, new GM with everything you need including the gasket and pick up tubes dipstick etc for I think around 350.  BRP has a real nice radiator for our cars with LS too, might want to take a look at... I think it's made by Dewitts.
Post by: 78TA_In87 on October 03, 2017, 09:37:35 PM
Yeah, I think that's the same pan i linked.  It's from GM and it's the one I am using.
And the radiator I got from BRP is made by DeWitts.  It even came with a Dewitts 40 page catalog.
Post by: beatboy77 on October 04, 2017, 08:20:15 PM
Can anyone share in detail what they have done for a rear end option when going to an LS3 type engine?
Josh
Post by: scarebird on October 04, 2017, 10:48:29 PM
your 8.5 will be fine.
Post by: beatboy77 on October 05, 2017, 10:10:55 AM
Are any modifications needed for it to handle the 500HP?
Josh
Post by: scarebird on October 05, 2017, 07:59:45 PM
I ran a Detroit Tru-Track with 31 spline axles.
Post by: gm muscle on November 19, 2017, 12:33:16 AM
X2...unless you're running slicks and launching hard every time, that diff will hold up fine. Besides, with street tires, they'll break loose before you can do damage.
Post by: Updated71 on November 19, 2017, 07:17:06 AM
I've had no issues with my stock rear running an Ls3 and 4L60E.  I'm not sure how much it helps, but I do have a heavy duty rear cover on it.  The pan that crate engine comes with is huge.  A Camaro or Corvette pan should work fine.  I was using a Corvette pan without issue.  I just removed it recently due to a subframe change.  It will no longer work with my current set up.  Make sure your harness/ECM/TCM are from a good supplier.  You get what you pay for here.
Post by: scarebird on November 19, 2017, 09:43:19 AM
Watch the driveline angle like a hawk here - I used the 2010 Camaro pan which came with the EROD motor.  It fits (barely), but makes the engine angle down too much.  Note the edges of the Holley pan - it is good for another 1/2" at least of lowering which will get you where you need to be angle wise.
(http://st.lowrider.com/uploads/sites/7/2012/01/1202-lrmp-11-o-GM-performance-LS3-transplant-oil-pans.jpg)
Here are three different oil pans that are currently the most popular. The first is the GM Camaro oil pan, but it did not work in our application, as the steering linkage won’t clear the oil pan. The second one is the LS retro-fit Holley oil pan. The third one is a GM muscle car oil pan, which is unused Hummer stockpile.
Post by: ryeguy2006a on November 21, 2017, 07:05:58 AM
Don't forget the 98-02 Fbody pans for 2nd gens. They fit almost like they were made for the car.
Post by: 78TA_In87 on November 21, 2017, 03:32:46 PM
Exactly.
That's the one I put a link for, up in this thread.
Post by: Bobby G on December 04, 2017, 08:50:30 PM
I used the Fpan in both of my LS3 swaps....fit perfect
