TAC Spotlight => Projects & Restorations => Topic started by: Ford5of5 on January 15, 2016, 09:40:08 PM
Title: Project 1979 Trans Am
Post by: Ford5of5 on January 15, 2016, 09:40:08 PM
So, I bought this '79 TA clone to use as a daily driver while building my '72 Esprit. It started life as a Gold 301 Formula with tan deluxe interior and no options other than t-tops. It had been converted to a TA with dark blue ext and blue birds with black deluxe int. It looked ok. Not great but not bad. I knew it had a few issues, but didn't care because it's just a kick around car. I only paid $6k for it with a rebuilt 400.
The first issue was the backyard paint job; it's not horrible, but had a few runs in the clear coat. Even though it has TA trim, it still had Formula decals on the doors and huge 400 badge from a 60's Bird on the rear spoiler. The dash had been hacked for a newer stereo and had a half dash cover installed. All the trim had been changed from tan to black with what looks like spray PAINT. And every piece of weather strip was dried out. The first thing I did was change the t-top and door weather strips and that quieted that car down big time.
A year or so after I bought it, I rebuilt the front suspension and steering. Just a weekend project that wouldn't break the bank. That's where the problems really started. I noticed a terrible repair to the radiator support using angle iron, but I ignored it because this was just a kick around car. My '72 project got sidetracked by my Dad's and brother's '55 Ford Vic. Then it got sidetracked by my Dad's '66 T-bird.
And now the '72 has been sidetracked by this car. The more I looked at the previous owner's repairs, the more I felt like I should just sell the car. Instead I decided to fix it. The PO managed to install the engine at an angle and askew. I know the engine should be offset to the car's center-line, but this is something you'd have to see. I'm really surprised there wasn't any odd vibrations. The motor mounts were trashed and welded in. The rad support was rotted beyond repair. There's some collision damage to the bumper plate. The toe panels, forward floor, rear floor, and rear seat panel on both sides had huge rot holes with repair panels welded on top and slathered in ROOFING CEMENT! The wrong body bushings were installed in rotted out holes; this is the most surprising problem because I drove the car that way for almost 2 years in an extremely dangerous state without even a clue.
So far, I replaced all the rot on the floor pans. I had to smooth the firewall because the PO bolted a remote oil filter through the gutter; it caused massive rot to the heater area. The upper cowl needed to be replaced and I had to fab windshield braces. All the body mounts and drivers forward torque box have been repaired and all the caged nuts have been re-caged. Thankfully the rockers are good! Next up is to replace the rear torque boxes.
These are my 'Birds:
(http://i.imgur.com/HYZUliZ.jpg) (http://imgur.com/HYZUliZ)
(http://i.imgur.com/2kLvmCI.jpg) (http://imgur.com/2kLvmCI)
Here's the blue 'Bird laid bare:
(http://i.imgur.com/GlyymmV.jpg) (http://imgur.com/GlyymmV)
(http://i.imgur.com/eAq70Sp.jpg) (http://imgur.com/eAq70Sp)
(http://i.imgur.com/vqqLaay.jpg) (http://imgur.com/vqqLaay)
(http://i.imgur.com/cQHz9oI.jpg) (http://imgur.com/cQHz9oI)
(http://i.imgur.com/xcsoUEP.jpg) (http://imgur.com/xcsoUEP)
(http://i.imgur.com/IGwVhHe.jpg) (http://imgur.com/IGwVhHe)
(http://i.imgur.com/IPgNZgk.jpg) (http://imgur.com/IPgNZgk)
(http://i.imgur.com/d7Bez6i.jpg) (http://imgur.com/d7Bez6i)
(http://i.imgur.com/tni66EW.jpg) (http://imgur.com/tni66EW)
(http://i.imgur.com/PM2AnCW.jpg) (http://imgur.com/PM2AnCW)
(http://i.imgur.com/yokC9Ti.jpg) (http://imgur.com/yokC9Ti)
(http://i.imgur.com/Nr6TSYr.jpg) (http://imgur.com/Nr6TSYr)
(http://i.imgur.com/nV8GR4Q.jpg) (http://imgur.com/nV8GR4Q)
(http://i.imgur.com/KXapz2F.jpg) (http://imgur.com/KXapz2F)
(http://i.imgur.com/GmECZwg.jpg) (http://imgur.com/GmECZwg)
(http://i.imgur.com/tgc2CBy.jpg) (http://imgur.com/tgc2CBy)
(http://i.imgur.com/jXVRbiv.jpg) (http://imgur.com/jXVRbiv)
(http://i.imgur.com/N5UFus7.jpg) (http://imgur.com/N5UFus7)
(http://i.imgur.com/2xu7w2S.jpg) (http://imgur.com/2xu7w2S)
(http://i.imgur.com/d4h8HYS.jpg) (http://imgur.com/d4h8HYS)
(http://i.imgur.com/66Ush5b.jpg) (http://imgur.com/66Ush5b)
(http://i.imgur.com/ll9S5tM.jpg) (http://imgur.com/ll9S5tM)
(http://i.imgur.com/ZWh0RyW.jpg) (http://imgur.com/ZWh0RyW)
(http://i.imgur.com/7Uz2XrF.jpg) (http://imgur.com/7Uz2XrF)
(http://i.imgur.com/s9U1oWi.jpg) (http://imgur.com/s9U1oWi)
(http://i.imgur.com/byjXl4C.jpg) (http://imgur.com/byjXl4C)
Title: Re: Project 1979 Trans Am
Post by: 1975 ta on January 15, 2016, 09:54:18 PM
nice work!
Post by: Ford5of5 on January 15, 2016, 10:20:54 PM
Thanks 75TA.
My plans are white TA clone with red interior and red birds. All bright work will be blacked out. Like this:
(http://i.imgur.com/5qNQ00Y.jpg) (http://imgur.com/5qNQ00Y)
Also in the works is vintage air, pw and pl, speedhuts, retrosound and maybe overdrive. It's not set in stone yet, but I'd like to use these switches for pw:
(http://i296.photobucket.com/albums/mm179/ford5of5/download2.jpg) (http://s296.photobucket.com/user/ford5of5/media/download2.jpg.html)
I may use the old pull for the fresh air vents, attached to a momentary switch, for the pl's. I was toying with one button locks, it's possible but beyond me and overly complicated. I may go with keyless entry and auto window up & down from a remote. Also, I want to change over all bulbs to led. I'll either build shades or use blackout tint on the t-tops. Pypes duel exhaust with TA splitters. Lots and lots of insulation. New front seat cushions.
If I can put together the cash, I'm gonna go with all new glass. Both side windows are scratched up pretty bad from worn out felts. I broke the windshield trying to remove it. I don't know what the PO used to set the glass, it was rock hard and I couldn't get it to cut with a wire or knife. Heat didn't help either. It too was showing scratches from the windshield wipers. The rear glass just looks shabby, it might clean up.
Post by: Ford5of5 on February 05, 2016, 08:40:27 PM
Here's a few rotisserie pics.
(http://i.imgur.com/mPU7ry8.jpg) (http://imgur.com/mPU7ry8)
(http://i.imgur.com/S02STkE.jpg) (http://imgur.com/S02STkE)
(http://i.imgur.com/erdBrPZ.jpg) (http://imgur.com/erdBrPZ)
(http://i.imgur.com/bv1FUWP.jpg) (http://imgur.com/bv1FUWP)
(http://i.imgur.com/f0iKtf8.jpg) (http://imgur.com/f0iKtf8)
The rockers are in pretty good condition. The springs braces however are completely shot. Even though the rocker wasn't rotted, I cut out out this section because it was bent up so bad and torn in a few spots. Then I repaired some of the wheel well.
(http://i.imgur.com/RTBzb8X.jpg) (http://imgur.com/RTBzb8X)
(http://i.imgur.com/70VINCC.jpg) (http://imgur.com/70VINCC)
(http://i.imgur.com/1NVorNZ.jpg) (http://imgur.com/1NVorNZ)
(http://i.imgur.com/zgxCrdj.jpg) (http://imgur.com/zgxCrdj)
(http://i.imgur.com/elOHso7.jpg) (http://imgur.com/elOHso7)
This is what it looks like when someone fixes a frame rail with 1/4" plate and bondo.
(http://i.imgur.com/9uQMRRx.jpg) (http://imgur.com/9uQMRRx)
Post by: Ford5of5 on February 07, 2016, 11:02:04 PM
Got a plasma cutter today. I used it to cut a patch out of 16g. My origional plan was to make the patch out of 2 pieces, but I was able to cut this odd shape out using a template. Plasma is dream compared to using an angle or die grinder.
(http://i.imgur.com/HwLXPRw.jpg) (http://imgur.com/HwLXPRw)
(http://i.imgur.com/dHg3U0U.jpg) (http://imgur.com/dHg3U0U)
(http://i.imgur.com/C1uqGBN.jpg) (http://imgur.com/C1uqGBN)
(http://i.imgur.com/VWj9qis.jpg) (http://imgur.com/VWj9qis)
Post by: Ford5of5 on February 20, 2016, 07:50:32 PM
Picture update
(http://i.imgur.com/TLqr1Fd.jpg) (http://imgur.com/TLqr1Fd)
(http://i.imgur.com/GN6rNkt.jpg) (http://imgur.com/GN6rNkt)
(http://i.imgur.com/Pp6awly.jpg) (http://imgur.com/Pp6awly)
(http://i.imgur.com/rY1XGXw.jpg) (http://imgur.com/rY1XGXw)
(http://i.imgur.com/cIB4IAx.jpg) (http://imgur.com/cIB4IAx)
(http://i.imgur.com/AF5cquL.jpg) (http://imgur.com/AF5cquL)
(http://i.imgur.com/WhFSenP.jpg) (http://imgur.com/WhFSenP)
(http://i.imgur.com/VanOVYM.jpg) (http://imgur.com/VanOVYM)
(http://i.imgur.com/ENvAnri.jpg) (http://imgur.com/ENvAnri)
(http://i.imgur.com/iaa2cFR.jpg) (http://imgur.com/iaa2cFR)
(http://i.imgur.com/ukWjL19.jpg) (http://imgur.com/ukWjL19)
(http://i.imgur.com/fqXLksX.jpg) (http://imgur.com/fqXLksX)
(http://i.imgur.com/uEuXpWT.jpg) (http://imgur.com/uEuXpWT)
(http://i.imgur.com/tohTlQe.jpg) (http://imgur.com/tohTlQe)
(http://i.imgur.com/Lq8zeKH.jpg) (http://imgur.com/Lq8zeKH)
(http://i.imgur.com/eyIJByP.jpg) (http://imgur.com/eyIJByP)
(http://i.imgur.com/H0kvH6O.jpg) (http://imgur.com/H0kvH6O)
(http://i.imgur.com/RFY3aqS.jpg) (http://imgur.com/RFY3aqS)
(http://i.imgur.com/1PzxRCI.jpg) (http://imgur.com/1PzxRCI)
(http://i.imgur.com/0h5NvZW.jpg) (http://imgur.com/0h5NvZW)
(http://i.imgur.com/IhJ4gR8.jpg) (http://imgur.com/IhJ4gR8)
(http://i.imgur.com/U31X7Tp.jpg) (http://imgur.com/U31X7Tp)
(http://i.imgur.com/X7bjWlU.jpg) (http://imgur.com/X7bjWlU)
(http://i.imgur.com/zDzAcai.jpg) (http://imgur.com/zDzAcai)
(http://i.imgur.com/vX0PKQc.jpg) (http://imgur.com/vX0PKQc)
(http://i.imgur.com/cLfgbkK.jpg) (http://imgur.com/cLfgbkK)
(http://i.imgur.com/lUsOZI7.jpg) (http://imgur.com/lUsOZI7)
(http://i.imgur.com/GNA20Ls.jpg) (http://imgur.com/GNA20Ls)
(http://i.imgur.com/003Lt5x.jpg) (http://imgur.com/003Lt5x)
(http://i.imgur.com/vfpgWcp.jpg) (http://imgur.com/vfpgWcp)
(http://i.imgur.com/ftYFiLP.jpg) (http://imgur.com/ftYFiLP)
(http://i.imgur.com/0SfygkK.jpg) (http://imgur.com/0SfygkK)
(http://i.imgur.com/k6Jny8F.jpg) (http://imgur.com/k6Jny8F)
(http://i.imgur.com/nnxvKfk.jpg) (http://imgur.com/nnxvKfk)
My welding is getting better. Some of them are still way too proud. I'm going to grind them a little bit more, but not much.
Post by: Spoon on February 20, 2016, 08:56:16 PM
Looks good!
Post by: mz-formula on May 19, 2016, 07:20:17 PM
Lookin good!  That frame rail patch came out awesome!
Post by: Ford5of5 on June 24, 2016, 04:20:53 PM
Pic update of frame rail fabrication:
(http://i.imgur.com/2jUpM6J.jpg) (http://imgur.com/2jUpM6J)
(http://i.imgur.com/SQhm4F7.jpg) (http://imgur.com/SQhm4F7)
(http://i.imgur.com/yUoTQz6.jpg) (http://imgur.com/yUoTQz6)
(http://i.imgur.com/3t5I8LV.jpg) (http://imgur.com/3t5I8LV)
(http://i.imgur.com/S4NATic.jpg) (http://imgur.com/S4NATic)
(http://i.imgur.com/i9ytf8s.jpg) (http://imgur.com/i9ytf8s)
(http://i.imgur.com/ZdBvH9T.jpg) (http://imgur.com/ZdBvH9T)
(http://i.imgur.com/pwPdWHt.jpg) (http://imgur.com/pwPdWHt)
(http://i.imgur.com/ZyShYaS.jpg) (http://imgur.com/ZyShYaS)
(http://i.imgur.com/UjKAiXW.jpg) (http://imgur.com/UjKAiXW)
(http://i.imgur.com/T6YQqKl.jpg) (http://imgur.com/T6YQqKl)
(http://i.imgur.com/ZYCUcZm.jpg) (http://imgur.com/ZYCUcZm)
(http://i.imgur.com/kulnaqM.jpg) (http://imgur.com/kulnaqM)
(http://i.imgur.com/nxEXfUU.jpg) (http://imgur.com/nxEXfUU)
(http://i.imgur.com/JrtTLRg.jpg) (http://imgur.com/JrtTLRg)
(http://i.imgur.com/c3D9tsN.jpg) (http://imgur.com/c3D9tsN)
(http://i.imgur.com/IhbhNhq.jpg) (http://imgur.com/IhbhNhq)
(http://i.imgur.com/JhMlaku.jpg) (http://imgur.com/JhMlaku)
(http://i.imgur.com/S9PPlh6.jpg) (http://imgur.com/S9PPlh6)
(http://i.imgur.com/6b60qxu.jpg) (http://imgur.com/6b60qxu)
(http://i.imgur.com/3jkFnfJ.jpg) (http://imgur.com/3jkFnfJ)
(http://i.imgur.com/InPq9Fn.jpg) (http://imgur.com/InPq9Fn)
(http://i.imgur.com/vJgHtMV.jpg) (http://imgur.com/vJgHtMV)
Quick tip: if you have steel that's been sitting around for awhile, then clean it off with acetone or something; a quick grind isn't enough to clean it up for welding. I bought this steel about two-three months ago. It came with a layer of oil/protectant of some kind that hardened on the metal. I didn't realize it was oil and my 1st welds were contaminated and full of holes.
Post by: Lev on July 02, 2016, 06:33:15 PM
great pics of the progress, thanks for sharing, back in high school in 1982, I test drove a white 79 with red interior & graphics that was for sale at chevy/Pontiac dealership, what a nice car, wish my Dad had said yes. looking forward to seeing your car finished, good luck, rock on!!
Post by: Ford5of5 on November 22, 2016, 11:17:10 PM
Pic update, I fixed the stripped threads in both upper shock mounts as well as some rot and then moved on to replacing the inner and out out tail panels. I think I may have hit a milestone as my floor repairs are complete! Only took me a year.
(http://i.imgur.com/pgte4bi.jpg) (http://imgur.com/pgte4bi)
(http://i.imgur.com/SjY2y0o.jpg) (http://imgur.com/SjY2y0o)
(http://i.imgur.com/6bB4VEk.jpg) (http://imgur.com/6bB4VEk)
(http://i.imgur.com/Z3mS9Ue.jpg) (http://imgur.com/Z3mS9Ue)
(http://i.imgur.com/ZobnpqR.jpg) (http://imgur.com/ZobnpqR)
(http://i.imgur.com/XsLE6JJ.jpg) (http://imgur.com/XsLE6JJ)
(http://i.imgur.com/qn0lbBE.jpg) (http://imgur.com/qn0lbBE)
(http://i.imgur.com/vGlYjdO.jpg) (http://imgur.com/vGlYjdO)
(http://i.imgur.com/ASEHweR.jpg) (http://imgur.com/ASEHweR)
(http://i.imgur.com/qyN3zCq.jpg) (http://imgur.com/qyN3zCq)
(http://i.imgur.com/6RdodXv.jpg) (http://imgur.com/6RdodXv)
(http://i.imgur.com/eN9amCw.jpg) (http://imgur.com/eN9amCw)
(http://i.imgur.com/E6cgOnK.jpg) (http://imgur.com/E6cgOnK)
(http://i.imgur.com/OyUQ4wD.jpg) (http://imgur.com/OyUQ4wD)
(http://i.imgur.com/3CRZ6k1.jpg) (http://imgur.com/3CRZ6k1)
(http://i.imgur.com/yKR8GRE.jpg) (http://imgur.com/yKR8GRE)
(http://i.imgur.com/5BLxU3j.jpg) (http://imgur.com/5BLxU3j)
(http://i.imgur.com/K9qY0AJ.jpg) (http://imgur.com/K9qY0AJ)
Post by: WHITETRASH on November 23, 2016, 08:19:49 AM
Wow. Lots of metal work, your repairs look great.
Post by: formula jg on December 05, 2016, 05:31:32 PM
I didn't realize you had this other thread going. More than half the pics are not showing but based on the ones that are showing all I gotta say it whaaaaaaat! You Got Heart brother!
Post by: Ford5of5 on December 10, 2016, 11:05:35 AM
Pic Update! Out of order, of course.
Floor repairs are finished, trunk is patched up, frame rail segment replaced, new inner and outer tail panel. Next step, Rust Bullet on in and out of floors and trunk.
(http://i.imgur.com/zIS5H6g.jpg) (http://imgur.com/zIS5H6g)
(http://i.imgur.com/0LfgNUx.jpg) (http://imgur.com/0LfgNUx)
(http://i.imgur.com/ZjNIehu.jpg) (http://imgur.com/ZjNIehu)
(http://i.imgur.com/mFm5xZP.jpg) (http://imgur.com/mFm5xZP)
(http://i.imgur.com/oaqNyjq.jpg) (http://imgur.com/oaqNyjq)
(http://i.imgur.com/EzxuFIX.jpg) (http://imgur.com/EzxuFIX)
(http://i.imgur.com/kt9Naun.jpg) (http://imgur.com/kt9Naun)
(http://i.imgur.com/8dB5UyW.jpg) (http://imgur.com/8dB5UyW)
(http://i.imgur.com/0kI964g.jpg) (http://imgur.com/0kI964g)
(http://i.imgur.com/VXYzdEj.jpg) (http://imgur.com/VXYzdEj)
(http://i.imgur.com/yIASl53.jpg) (http://imgur.com/yIASl53)
(http://i.imgur.com/tNQ2RZb.jpg) (http://imgur.com/tNQ2RZb)
(http://i.imgur.com/BhT1fSW.jpg) (http://imgur.com/BhT1fSW)
(http://i.imgur.com/FehWXqK.jpg) (http://imgur.com/FehWXqK)
(http://i.imgur.com/P1MN6Qx.jpg) (http://imgur.com/P1MN6Qx)
(http://i.imgur.com/g6ARgja.jpg) (http://imgur.com/g6ARgja)
(http://i.imgur.com/yeLb8QD.jpg) (http://imgur.com/yeLb8QD)
(http://i.imgur.com/iZMjetu.jpg) (http://imgur.com/iZMjetu)
(http://i.imgur.com/C55vubJ.jpg) (http://imgur.com/C55vubJ)
Here's the replacement frame rail. In regards to this particular piece, I will yield to my friend Doright. The fitment was horrible and required a lot of cutting, banging and rewelding.
(http://i.imgur.com/NHkxrgl.jpg) (http://imgur.com/NHkxrgl)
(http://i.imgur.com/AWUplwj.jpg) (http://imgur.com/AWUplwj)
(http://i.imgur.com/3S6KWWc.jpg) (http://imgur.com/3S6KWWc)
(http://i.imgur.com/HO9Xp2S.jpg) (http://imgur.com/HO9Xp2S)
(http://i.imgur.com/vFcYuRP.jpg) (http://imgur.com/vFcYuRP)
(http://i.imgur.com/RNDlEms.jpg) (http://imgur.com/RNDlEms)
(http://i.imgur.com/3Zbz5Qj.jpg) (http://imgur.com/3Zbz5Qj)
(http://i.imgur.com/hfJvfOv.jpg) (http://imgur.com/hfJvfOv)
(http://i.imgur.com/IDKGv7a.jpg) (http://imgur.com/IDKGv7a)
(http://i.imgur.com/9nK9hui.jpg) (http://imgur.com/9nK9hui)
(http://i.imgur.com/i4CquaU.jpg) (http://imgur.com/i4CquaU)
(http://i.imgur.com/SWvnzaG.jpg) (http://imgur.com/SWvnzaG)
(http://i.imgur.com/ucTwzoM.jpg) (http://imgur.com/ucTwzoM)
(http://i.imgur.com/bXOJ9Fi.jpg) (http://imgur.com/bXOJ9Fi)
(http://i.imgur.com/IPUUmdq.jpg) (http://imgur.com/IPUUmdq)
The AMD inner and outer panels fit like a glove. By accident I bought two different manufacturer's inner panels. One was AMD and the I THINK the other was Goodmark. Both AMD panels had crisper profiles, all the holes were either dead on or very close and pretty much fell into to place.
(http://i.imgur.com/GqXfb1Z.jpg) (http://imgur.com/GqXfb1Z)
(http://i.imgur.com/b1ZCgtp.jpg) (http://imgur.com/b1ZCgtp)
The trunk closed correctly on the first try, YEA!
(http://i.imgur.com/KR4a4Bm.jpg) (http://imgur.com/KR4a4Bm)
(http://i.imgur.com/PV9bwu4.jpg) (http://imgur.com/PV9bwu4)
(http://i.imgur.com/5W1YKo6.jpg) (http://imgur.com/5W1YKo6)
Post by: Jack on December 10, 2016, 11:06:23 AM
I'm glad you're back at it.
Post by: MNBob on December 10, 2016, 11:46:04 AM
Incredible work, go power and patience!  You must have to do a lot of measuring to make all of this fit together with all of the parts gone.  Looks great.
Post by: formula jg on December 10, 2016, 02:28:21 PM
How did you weld the inner tail panel to the gas tank bracket, plug weld from outside or run a bead along each of the 3 gas tank bracket tabs from the inside?
From the pics it looks like the trunk gutter corners needed to be banged down and shaped to the new panel gutter, correct?
Now that you've been intimate with that rear tail panel how much less (or more) shaping of the gutter corners would be required if I separated that gutter strip from the original panel and attached the new panel along the original strip as we discussed in my current tail panel thread?
The pics are fantastic but I gotta admit some are like a horror movie, hard to look at or recognize when its all cut up.....hehehehe.
Post by: FormTA on December 10, 2016, 02:30:30 PM
Wow!
Post by: Ford5of5 on December 10, 2016, 04:16:01 PM
Lots and lots of measurements and a few eyeball guesstimates were necessary. Everyplace you see blue tape is a measuring point, there's also several on the floor of the garage. Thanks to the engineers at GM there's isn't a single symmetric or straight line on these cars! LOL That's the only nice part about Fords, I don't think there are any others. :lol:
For the passenger side gas tank bracket I drilled through the inner panel and plug welded it. Whenever possible, you want your thickest metal to be the base of a plug weld. The drivers side I think should be welded in the same manner but too much of mine was missing. Ill' probably add a tab to it and weld it to the inner panel from the back with a plug.
The quarter corners got bent up because I looking for welds and how it was put together. They tapped back into place real easy, but I haven't welded them because the quarters are going to be replaced as well. I did weld the gutter to the outer panel.
Post by: mz-formula on December 11, 2016, 07:38:48 AM
great work on your bird!    Yours looks to have weathered time about the same as mine did over all, but you are making good progress on getting it back on the road.
Post by: Ford5of5 on December 11, 2016, 02:27:22 PM
Formula JG, I forgot to answer all of your question. At this point, I believe it to be easier to remove the entire panel; this stuff is always a matter of opinion, though. You would need to pop all the welds across the outer gutter and the lock cage as opposed to 3 or 4 on either side. Then you need to hope that the new panel matches as well as the old one, which I THINK it will. Either way, the quarter panel gutters will need to be detached and the taillight extensions will need to be bent out of the way.
I'm fairly sure that there is no saving the trunk gasket in either scenario. Mine was glued in completely, 100%. It's been awhile since I've done weatherstripping but I think you're only suppose to use the glue in several areas and not the entire gasket. For instance, I think it's suppose to only be glued the beginning and end pieces and any corners.
I'm definitely hesitant to say it will or won't work because I just don't know. You're idea totally seems doable. I'm just not sure if it's worth the effort. If you go that route take pics! Generally, I like the idea of replacing/disturbing as little good, origional material/paint as possible. Problem is I prefer easier work even if there's more of it. :shock:  This is first time that I've gone this deep into a car. Giggity. In the past, I would have just sold the car.
Post by: NOT A TA on December 11, 2016, 04:08:45 PM
Wow are you in deep! You have my respect for the perseverance it takes to do all that metal work on a clone. Keep at it!
Post by: Ford5of5 on December 11, 2016, 05:43:01 PM
Well, I have to admit I'm enjoying the metal work. Many of my contracting-customers have made the remark that demolition must be the fun part of the job. For me, it was always putting things back together that I enjoyed. Plus, I enjoy sorta reverse engineering from pictures and rotted-out pieces of steel. From the get go, I did not plan to do this much work, especially to a common 1979. I just couldn't leave the mess that the PO made. Now, it's become the practice run for my '72 Esprit. Now that car is a HORROR SHOW!
Post by: formula jg on December 11, 2016, 05:53:16 PM
I posted a reply on my thread, link here:
http://transamcountry.com/community/index.php?topic=75701.40
Post by: Ford5of5 on December 29, 2016, 04:11:02 AM
Pic Update! All frame, floor and trunk repairs have been finished. The floor then got stripped and coated with 2 coats of Rust Bullet, 2 coats of home made Lizard Skin on the exterior, 2 coat of RB and 1 coat of home made LS on the interior, then a final coat of white on the exterior. I really should've left it silver or went with black. The texture of the microspheres requires more paint to completely hide than I bought. A quart should've been enough for 2 coats, it took the entire quart just to get coverage. It'll never been seen, I guess.
(http://i.imgur.com/CvKCyno.jpg) (http://imgur.com/CvKCyno)
(http://i.imgur.com/TtgdcdA.jpg) (http://imgur.com/TtgdcdA)
(http://i.imgur.com/tEJjjQm.jpg) (http://imgur.com/tEJjjQm)
(http://i.imgur.com/xgNjxdz.jpg) (http://imgur.com/xgNjxdz)
(http://i.imgur.com/Ai84O1s.jpg) (http://imgur.com/Ai84O1s)
(http://i.imgur.com/Gnk9gOr.jpg) (http://imgur.com/Gnk9gOr)
(http://i.imgur.com/JHaphWM.jpg) (http://imgur.com/JHaphWM)
(http://i.imgur.com/c48FnMF.jpg) (http://imgur.com/c48FnMF)
(http://i.imgur.com/uBDG9p2.jpg) (http://imgur.com/uBDG9p2)
(http://i.imgur.com/bNv1hMZ.jpg) (http://imgur.com/bNv1hMZ)
(http://i.imgur.com/Qtx5Vsi.jpg) (http://imgur.com/Qtx5Vsi)
(http://i.imgur.com/VDN8A2n.jpg) (http://imgur.com/VDN8A2n)
(http://i.imgur.com/w6P7hlN.jpg) (http://imgur.com/w6P7hlN)
(http://i.imgur.com/rTYfX5D.jpg) (http://imgur.com/rTYfX5D)
(http://i.imgur.com/aghNWWV.jpg) (http://imgur.com/aghNWWV)
(http://i.imgur.com/cBQINcc.jpg) (http://imgur.com/cBQINcc)
(http://i.imgur.com/JQJ4m4n.jpg) (http://imgur.com/JQJ4m4n)
(http://i.imgur.com/JyajpOm.jpg) (http://imgur.com/JyajpOm)
Post by: Jack on December 29, 2016, 10:06:37 PM
That should last another 40 years, nice work Mr. Ford.
Post by: Turbo Steve on December 30, 2016, 06:16:16 AM
HARD CORE!
Lol nice work!
Post by: mark369 on January 14, 2017, 05:20:29 PM
Wow I left my shock tower in when I removed broke off bolts.   How is your garage so clean?   It is supper fun when my mechanic friend with ocd comes over to mine he cant stay in it.
  that is some good work.  looks factory.   Love the rotisserie.   Did you weigh the bondo you took out?   We tried selling a box of my original Pontiac rust at nationals a couple years  a go !
Post by: Ford5of5 on January 15, 2017, 09:32:18 PM
HA! The garage isn't clean anymore. The plan is to do a complete and thorough cleaning of the garage once the car is back on its rear wheels and off of the rotisserie. There's dust from grinding everywhere and residue on the floor from using phosphoric acid.
Post by: mark369 on January 17, 2017, 08:49:11 PM
  Ok I misspoke, I meant cluttered.  compared to mine yours is a "clean room".
Post by: Ford5of5 on February 16, 2017, 11:05:12 PM
Pic update. Got the rear end painted, everything on the subframe painted and all hoses and lines ready to assemble. I still need to strip and paint subframe and then I'm ready to get the car off the rotisserie.
(http://i.imgur.com/weVRzx1.jpg) (http://imgur.com/weVRzx1)
(http://i.imgur.com/wInv56N.jpg) (http://imgur.com/wInv56N)
(http://i.imgur.com/y9aCq1S.jpg) (http://imgur.com/y9aCq1S)
(http://i.imgur.com/FzdpG07.jpg) (http://imgur.com/FzdpG07)
(http://i.imgur.com/q4WiaNq.jpg) (http://imgur.com/q4WiaNq)
(http://i.imgur.com/vsdSm7c.jpg) (http://imgur.com/vsdSm7c)
(http://i.imgur.com/Ak8uAEM.jpg) (http://imgur.com/Ak8uAEM)
(http://i.imgur.com/wFuXWyU.jpg) (http://imgur.com/wFuXWyU)
(http://i.imgur.com/x0yP7cn.jpg) (http://imgur.com/x0yP7cn)
(http://i.imgur.com/71Kh4Se.jpg) (http://imgur.com/71Kh4Se)
(http://i.imgur.com/l5OrBAT.jpg) (http://imgur.com/l5OrBAT)
(http://i.imgur.com/IzRhUnI.jpg) (http://imgur.com/IzRhUnI)
(http://i.imgur.com/p1q6glR.jpg) (http://imgur.com/p1q6glR)
(http://i.imgur.com/rwT3pEa.jpg) (http://imgur.com/rwT3pEa)
(http://i.imgur.com/qJvEy2F.jpg) (http://imgur.com/qJvEy2F)
(http://i.imgur.com/sgvB64e.jpg) (http://imgur.com/sgvB64e)
(http://i.imgur.com/5VPBNW4.jpg) (http://imgur.com/5VPBNW4)
(http://i.imgur.com/pmkGaEc.jpg) (http://imgur.com/pmkGaEc)
(http://i.imgur.com/3OAzIML.jpg) (http://imgur.com/3OAzIML)
(http://i.imgur.com/tnSQd2I.jpg) (http://imgur.com/tnSQd2I)
(http://i.imgur.com/H9ZGye0.jpg) (http://imgur.com/H9ZGye0)
(http://i.imgur.com/4airy86.jpg) (http://imgur.com/4airy86)
(http://i.imgur.com/NvGmARL.jpg) (http://imgur.com/NvGmARL)
(http://i.imgur.com/BSlysSW.jpg) (http://imgur.com/BSlysSW)
Post by: roadking77 on February 17, 2017, 04:08:25 PM
Clean shiny parts are nice. For some reason I thought you were in Mass, I don't see any snow in your pics.
Post by: jonathonar89 on February 17, 2017, 10:46:30 PM
Looking good sir.  Admirable to see all that work being done DIY.
Post by: Ford5of5 on February 18, 2017, 11:32:36 AM
I am in Mass. The powerwashing was done a few days before the last big storm. You know what they say about Massachusetts, if you don't like the weather just wait 5 minutes, it'll change.
Post by: Ford5of5 on March 12, 2017, 09:08:35 PM
I got the car off the rotisserie this weekend. It's kinda exciting to see it back on the ground, even if it's only on two wheels. Also got the entire frame prepped for reassembly, just waiting on an IROC steering box and pump.
Oddly enough, the hardest thing so far was installing the pre-bent brake and fuel lines! :eek: :lol: Thanks to everyone that helped me out with that. I had no originals to go by and some of the clip shapes are just plain confounding.
Here's some pics:
(http://i.imgur.com/CbJoiKd.jpg) (http://imgur.com/CbJoiKd)
(http://i.imgur.com/8EEf8DP.jpg) (http://imgur.com/8EEf8DP)
(http://i.imgur.com/Kkc5WLv.jpg) (http://imgur.com/Kkc5WLv)
(http://i.imgur.com/NkMAmNb.jpg) (http://imgur.com/NkMAmNb)
Post by: Jack on March 13, 2017, 05:44:42 AM
Good progress, it'll be ready for paint in no time.
Post by: Ford5of5 on March 23, 2017, 04:30:00 PM
I painted the firewall a few days ago. I gotta say that I love the way HVLP guns work. My Dad suggested that I paint it black and I'm thinking he may be right. It looks good but will probably get dirty real easy. I was planning on painting the car myself. Now, I'm kinda reconsidering. The firewall came out good, no runs, misses or stripping but, I feel like I would need a lot more practice before doing a whole car.
I'm planning on getting the subframe and engine in this weekend. Can't wait for the car to be at least mobile. Then the doors can go back on and I can get into the special hell that is replacing rear quarters.
(http://i.imgur.com/8ZqDW7e.jpg) (http://imgur.com/8ZqDW7e)
(http://i.imgur.com/oIzmF2F.jpg) (http://imgur.com/oIzmF2F)
(http://i.imgur.com/Ft7AGmN.jpg) (http://imgur.com/Ft7AGmN)
(http://i.imgur.com/ExsTTjr.jpg) (http://imgur.com/ExsTTjr)
Post by: FormTA on March 23, 2017, 04:48:52 PM
I say paint it yourself! For your first paint job. Get some single stage paint. You can use the Shop line or DCC PPG paint (others will work too but these are ones I know). No clear to mess with and if you screw something up you can just wet sand it down and buff it to a shine. I have been painting for years and I use both base clear and single stage. With my TA I'm going with single as it will be a driver and I can do touch up pretty easy with single. Some guys will even wet sand single and then clear it for a really deep look.
Just saying, I think you can do it and it will come out great.
Post by: Ford5of5 on April 01, 2017, 11:59:47 PM
Got my subframe back on. Either I'm that good at repairing metal or darn lucky! :lol: Chances are it's probably a little of both. The subframe lined up without any issues at all. I'm very pleased considering how much work I did to the frame and forward torque boxes. I got my fingers crossed that I don't find out something is very wrong later down the road. I upgraded my steering gear and pump with Iroc stuff. The old gear had 3 revolutions and the new is 2.5. The old one had a leak from the front cap that I fixed with a rebuild kit. The repair worked fine for a year; when I started the car up after winter storage the front cap popped off upon startup with a very loud bang and poured all the steering fluid on my driveway.
(http://i.imgur.com/SiQLIot.jpg) (http://imgur.com/SiQLIot)
(http://i.imgur.com/A9zqGDb.jpg) (http://imgur.com/A9zqGDb)
(http://i.imgur.com/mQbV5ma.jpg) (http://imgur.com/mQbV5ma)
(http://i.imgur.com/Wx7CVrh.jpg) (http://imgur.com/Wx7CVrh)
Next up: paint and install steering column, paint dash carmine red, install engine, install core support and radiator. I need to get my engine running again because I think I may need a new timing chain or balancer. I think my timing mark is jumping around. The big problem is that I been working on so many old cars that I can't remember if it was this car or one of the others. If I need to replace the timing chain then I'm probably gonna do a cam swap once I find out what the cam is.
Post by: Jack on April 02, 2017, 04:41:27 AM
That's nothing you'll have it done before the snow melts... lol
Post by: Grand73Am on April 05, 2017, 04:43:29 PM
(http://i1173.photobucket.com/albums/r594/christopher_ford2/1979%20Firebird/IMG_20170401_231025683_HDR_zpsszfqczxf.jpg) (http://s1173.photobucket.com/user/christopher_ford2/media/1979%20Firebird/IMG_20170401_231025683_HDR_zpsszfqczxf.jpg.html)
I've been doing similar work on my front suspension, steering and brakes. This photo might contain an "oops". Hope you didn't forget to install the left upper control arm bumper  :shock: .
Post by: Ford5of5 on April 05, 2017, 08:33:20 PM
@ FormTA, I'm probably gonna try to paint it myself because I'm cheap. lol Doing the firewall and floor was pretty easy. I'm just worried about doing an entire car where misses and tiger stripes are easily noticeable.
@ Jack, you always have words of encouragement. Thanks, it's appreciated on such a big project.
@ Grand73am HA, LOL! I pulled it out because I was afraid that I wouldn't be able to get the control arms to close up enough to thread the ball joint nuts without an engine to counter the jack. I left it in on the other side, turns out it wasn't an issue.
Post by: No Moa on April 06, 2017, 08:16:31 AM
WOW!!!!
Post by: mz-formula on April 06, 2017, 10:51:11 AM
Looking great!  Keep at it!
Post by: FULZGOLD on April 06, 2017, 11:38:59 AM
A friend taught me how to paint way back in high school. (80-82) He'd done a few dozen cars. I ended up doing about 5 myself with pretty good results. All single stage enamel. If I did it, I'm sure you can! It's just speed and distance...lol
Great work so far!
Post by: formula jg on April 07, 2017, 10:46:45 AM
When your done with this project I can use a little help over here, don't worry it will feel just like home...snow and all...hehehe.
Post by: Ford5of5 on July 06, 2017, 02:31:02 PM
Pic Update:
(http://i.imgur.com/FX3FRLK.jpg) (http://imgur.com/FX3FRLK)
(http://i.imgur.com/QPhbgRh.jpg) (http://imgur.com/QPhbgRh)
(http://i.imgur.com/l5ofQvw.jpg) (http://imgur.com/l5ofQvw)
(http://i.imgur.com/roIUHGw.jpg) (http://imgur.com/roIUHGw)
(http://i.imgur.com/DkVWJjO.jpg) (http://imgur.com/DkVWJjO)
(http://i.imgur.com/K0cnVBs.jpg) (http://imgur.com/K0cnVBs)
(http://i.imgur.com/HwU31V1.jpg) (http://imgur.com/HwU31V1)
Everyone likes to notice and mention it when they see alcohol in my pics. THAT'S MOUNTAIN DEW!
(http://i.imgur.com/NH4RbGS.jpg) (http://imgur.com/NH4RbGS)
(http://i.imgur.com/exeXBa8.jpg) (http://imgur.com/exeXBa8)
Post by: Ford5of5 on July 06, 2017, 02:39:56 PM
I re-linked all my pics through Imgur due to photobuckets "Great Extortion of 2017".
Post by: roadking77 on July 06, 2017, 06:31:33 PM
Thanks for doing that. I guess we will all get another pic. host and start over again. Its a shame all of this stuff is now lost, but oh well,  hope PB is happy!
BTW, nice work on the steering column.
Post by: Ford5of5 on July 06, 2017, 06:45:13 PM
Unfortunately, I forgot to take pics of the break down and rebuild of the column. It was rather easy, just very time consuming because of all the parts. I still can't believe how much filth was inside the column and all the grease inside turned to something like glue or very loose clay. I used this to help with the rebuild, it's a pdf entitled Inside the GM Tilt Steering Column by Jazzman: http://www.crankshaftcoalition.com/wiki/images/d/d6/Jazzman_Steering_Rack_Rebuild.pdf (http://www.crankshaftcoalition.com/wiki/images/d/d6/Jazzman_Steering_Rack_Rebuild.pdf) The column used in the pdf is for a tilt column from a manual Fiero but is close enough. I lubed everything, replaced all the seals, installed a new ignition switch, and painted it Carmine Red. I also bought a set of locks for the door and ignition that are all keyed alike. I'll add some pics of that soon.
Post by: Ford5of5 on July 15, 2017, 04:02:32 PM
YAY! 4 wheels again!
I installed the steering linkage and column today. Then put the front wheels on. Next is the brake booster and master cylinder. Once I get the mystery trans clip figured out, the engine is going back in.
(http://i.imgur.com/0TIkuxl.jpg) (http://imgur.com/0TIkuxl)
(http://i.imgur.com/qKDwyZw.jpg) (http://imgur.com/qKDwyZw)
Post by: Ford5of5 on July 18, 2017, 05:17:57 PM
Finished up and bled the brakes. Engine and headers are next.
(http://i.imgur.com/WEEv2s4.jpg) (http://imgur.com/WEEv2s4)
(http://i.imgur.com/FBssKHH.jpg) (http://imgur.com/FBssKHH)
(http://i.imgur.com/aIpNSAH.jpg) (http://imgur.com/aIpNSAH)
(http://i.imgur.com/ooDHOkk.jpg) (http://imgur.com/ooDHOkk)
(http://i.imgur.com/LuB6YfG.jpg) (http://imgur.com/LuB6YfG)
Post by: Ford5of5 on July 24, 2017, 11:40:00 AM
Installed my engine with the headers already installed. I only tried this because I saw an internet argument about if it could be done in a Firebird. I can say yes, it can be done. But it's not worth the extra hassle and very much depends on what headers you are running. I don't know who manufactured my headers, but the flanges kept getting stuck on my floor board. Going between a jack and the cherry picker you can make it happen.
Now, I gotta pull the engine back out to re-route the fuel return line; it's touching the driver's side header. I will be removing the headers for the removal and reinstall.  :lol: I will also fix all the paint I gouged trying to install an engine with the headers attached! :lol: :lol: In the end, it's not worth the trouble. Just tie your headers to the subframe, drop in the motor and tranny, and then attach your headers. It's a much easier procedure, IMO.
(http://i.imgur.com/7dIApuR.jpg) (http://imgur.com/7dIApuR)
(http://i.imgur.com/Lo8LGzF.jpg) (http://imgur.com/Lo8LGzF)
(http://i.imgur.com/RYcpTts.jpg) (http://imgur.com/RYcpTts)
(http://i.imgur.com/0IOS1ju.jpg) (http://imgur.com/0IOS1ju)
As a side note, I also installed a set of Inline Tube tranny cooler lines.
Post by: Ford5of5 on July 24, 2017, 09:09:52 PM
Got the engine out and back in, only took a few hours. I rerouted the fuel return line and fixed the nicked paint. Also added jumper for solenoid upgrade. It's no contest, installing the headers after the engine is installed was 10x's easier. I did need to remove my oil adapter, though.
(http://i.imgur.com/81jKSKM.jpg) (http://imgur.com/81jKSKM)
(http://i.imgur.com/JBU2G0z.jpg) (http://imgur.com/JBU2G0z)
(http://i.imgur.com/3kVfqBB.jpg) (http://imgur.com/3kVfqBB)
(http://i.imgur.com/3cwv92b.jpg) (http://imgur.com/3cwv92b)
Post by: Ford5of5 on August 20, 2017, 09:56:17 PM
Photo Update
Here's a few pics of the tranny cooler line and battery cable clips, mostly for comparison:
(http://i.imgur.com/wCyVGQS.jpg) (http://imgur.com/wCyVGQS)
(http://i.imgur.com/JoL2iTd.jpg) (http://imgur.com/JoL2iTd)
I made my own steering column levers. This route cost less than $20. The cost and hassle of buying proper levers was just too much, for me. I posted this over in the Interior section if anyone wants more info on this.
(http://i.imgur.com/5jN1nje.jpg) (http://imgur.com/5jN1nje)
(http://i.imgur.com/tMOr7m1.jpg) (http://imgur.com/tMOr7m1)
(http://i.imgur.com/IDXRJmi.jpg) (http://imgur.com/IDXRJmi)
(http://i.imgur.com/3lBScXd.jpg) (http://imgur.com/3lBScXd)
(http://i.imgur.com/J772q5R.jpg) (http://imgur.com/J772q5R)
(http://i.imgur.com/bzGTzNH.jpg) (http://imgur.com/bzGTzNH)
(http://i.imgur.com/1bKgBgh.jpg) (http://imgur.com/1bKgBgh)
(http://i.imgur.com/o4Uy46c.jpg) (http://imgur.com/o4Uy46c)
(http://i.imgur.com/R14dLnl.jpg) (http://imgur.com/R14dLnl)
(http://i.imgur.com/JwozfGC.jpg) (http://imgur.com/JwozfGC)
(http://i.imgur.com/WdcIlgu.jpg) (http://imgur.com/WdcIlgu)
(http://i.imgur.com/zFvStu2.jpg) (http://imgur.com/zFvStu2)
Post by: Ford5of5 on August 20, 2017, 10:36:17 PM
I've been taking a bit of a break from this project, but I couldn't keep my mind off of it. Of particular curiosity to me, is that the PO used a Torker II intake and a 600cfm E-carb. From what I've read this set-up shouldn't work very well. I never raced the car or used anything to gauge its speed, but it always felt fast. In my research, I came across one theory that said the volume of the Torker II made up for the small cfm's of the carb. I don't know, but if you're an engine guy I'd like to know what you think.
I took the front of the engine apart in order to find out what kind of cam was in there and also because my timing mark floated around a bit; I was expecting a bad chain. Turns out a floating timing mark is usually caused by a bad dizzy, intake leaks/vacuum disturbances or a poor tune. In my case, the dizzy weights were rusty and hanging up a bit; the chain looked new and had about 1* of slop. Also there's a lot of slop in both directions and noticeable wear on the dizzy gear. New dizzy and re-curve kit are en route.
I still wanted to know what the cam specs were. So, I made my own degree wheel and bought a cheap dial gauge from Harbor Freight. The cam spec'd at a duration of 204/225 at .050 with lift of .408/.432. Best I can figure it's an an older, generic grind. It had no id etched into it, anywhere.
Also on order, a Voodoo 256 cam and lifters, Lunati valve springs, and a Jet stage 2 Q-jet. My credit card is melting. I'll be using an early 70's factory intake. Using Comp Cam's Camquest puts my new combo at 305 hp at 4500 and 445 ftlbs at 2500. I had to use Comp Cams XE256 for the program to work. I have no idea how accurate my assumptions will be. Guess we're gonna find out! :lol: :lol:
Thanks to all the folks over at the Choosing the Right Combo posting for helping me pick a cam. There's so much to learn about cams that it is a daunting task to pick one.
(http://i.imgur.com/LZ4YtxU.jpg) (http://imgur.com/LZ4YtxU)
(http://i.imgur.com/FYN0oFs.jpg) (http://imgur.com/FYN0oFs)
(http://i.imgur.com/LLSdaGF.jpg) (http://imgur.com/LLSdaGF)
(http://i.imgur.com/GYDbwYa.jpg) (http://imgur.com/GYDbwYa)
Post by: Bale9 on August 21, 2017, 12:05:19 AM
Nice work.
Very creative with the indicator levers.
The front clip overhaul come up good too.
Post by: MNBob on August 21, 2017, 10:32:12 AM
I think you will love that cam!  Should be the ultimate torque and good manners for the 400.  I am considering the same thing in a roller.  Please give us a report when get it going.
Post by: Ford5of5 on October 18, 2017, 01:32:43 PM
I finished my cam install. It was really cool seeing how the degree wheel worked. IIRC, everything on the cam card came within 1 or 2* of spec. Pretty all right for my build, LOL. Kind of funny, every single time I replace an oil pan gasket I need to buy 2 of 'em. I have this dumb habit of forgetting that big torque wrenches usually don't work so well on the smaller side of the scale and I end up squeezing the gasket out. I think I've been through 4 or 5 on this engine alone. 15lbs is all that is needed!
I bought a new timing cover from Rock Auto. It's a fairly nice casting. The only issue was that some of the timing numbers are a little hard to read, but all the marks are clear. I painted them to make life a little easier. Also, I replaced the harmonic dampener. The old one was probably ok, but looked just a little iffy. The only issue is that the crank pulley bolts are metric.
The new distributor, also from Rock Auto, is real nice. The old one had rusty springs and weights that were getting hung up just a little. The vertical and lateral slop were noticeably too much; there was also a lot of wear of the distributor gear. These are the most likely reasons why I was getting a floating timing mark. I was able to fully drop in my dizzy at 11, 12, 1 and 2 o'clock with the #1 piston at TDC on the compression stroke. I also cleaned up an iron intake with vinegar and painted the engine, AGAIN, before reinstalling.
I then started hacking of my rear quarter. I only wanted to remove one side at a time, but my brother cut out the passenger side before I could tell him to stop. I put the new quarter in place just to see how it looks. Definitely gonna need some adjusting. That'll be my next post.
Here's my photo dump:
(http://i.imgur.com/3CCTKoW.jpg) (https://imgur.com/3CCTKoW)
(http://i.imgur.com/VqRsQsk.jpg) (https://imgur.com/VqRsQsk)
(http://i.imgur.com/TrmzJ69.jpg) (https://imgur.com/TrmzJ69)
(http://i.imgur.com/Pg26CpQ.jpg) (https://imgur.com/Pg26CpQ)
(http://i.imgur.com/XbdzYj2.jpg) (https://imgur.com/XbdzYj2)
(http://i.imgur.com/p7sPDxE.jpg) (https://imgur.com/p7sPDxE)
(http://i.imgur.com/AosCOZ3.jpg) (https://imgur.com/AosCOZ3)
(http://i.imgur.com/19w2xS5.jpg) (https://imgur.com/19w2xS5)
(http://i.imgur.com/KaVVMEA.jpg) (https://imgur.com/KaVVMEA)
(http://i.imgur.com/1lHwMNv.jpg) (https://imgur.com/1lHwMNv)
(http://i.imgur.com/h73sQ7C.jpg) (https://imgur.com/h73sQ7C)
(http://i.imgur.com/CicF57q.jpg) (https://imgur.com/CicF57q)
(http://i.imgur.com/YQlM79e.jpg) (https://imgur.com/YQlM79e)
(http://i.imgur.com/SXhoLNx.jpg) (https://imgur.com/SXhoLNx)
(http://i.imgur.com/BV5sz9c.jpg) (https://imgur.com/BV5sz9c)
(http://i.imgur.com/ydTqKAu.jpg) (https://imgur.com/ydTqKAu)
(http://i.imgur.com/YQkkUQ6.jpg) (https://imgur.com/YQkkUQ6)
(http://i.imgur.com/z7S7Lkz.jpg) (https://imgur.com/z7S7Lkz)
(http://i.imgur.com/oQ5FR0V.jpg) (https://imgur.com/oQ5FR0V)
(http://i.imgur.com/hlULiLg.jpg) (https://imgur.com/hlULiLg)
(http://i.imgur.com/FyB6IKd.jpg) (https://imgur.com/FyB6IKd)
(http://i.imgur.com/hkv95Q9.jpg) (https://imgur.com/hkv95Q9)
(http://i.imgur.com/JyaPj9r.jpg) (https://imgur.com/JyaPj9r)
(http://i.imgur.com/cJP4MA1.jpg) (https://imgur.com/cJP4MA1)
(http://i.imgur.com/NyqS5dU.jpg) (https://imgur.com/NyqS5dU)
Cat Tax
(http://i.imgur.com/5EBCg6K.jpg) (https://imgur.com/5EBCg6K)
Post by: formula jg on October 18, 2017, 04:58:56 PM
Thanks for all the pics and details, it's all a great reference for us to use.
Just to go back to the dizzy, how much floating were you get on the old one?
I often wonder what is acceptable and if the more cam you have the more gyration you get at the timing marks.
Post by: LeighP on October 18, 2017, 11:51:49 PM
Great project.....love the home made control levers.
I see you've also got a feline Quality Assurance Manager......  :lol:
Post by: Ford5of5 on October 19, 2017, 12:58:59 PM
My timing mark, when on a timing light, would easily jump around 3-4* before and after 10*; occasionally it would jump 30*. Idle was fairly smooth with no signs of an aggressive cam. I set my timing with a pressure gauge because of it.
Someone please correct me if I'm wrong, the timing mark should appear static when viewed with a timing light. The exception would be aggressive cammed engines or worn parts.
That's Jeff, he's inspects all my empty boxes.
Post by: LeighP on October 20, 2017, 06:04:36 AM
Yes, the timing mark should be fairly stable under the light.
Post by: Ford5of5 on November 20, 2017, 09:54:02 PM
Started installing the rear quarter. It's been off and on about a dozen times now. Adjustments weren't that bad. The AMD (advertised as new tooling) pressing isn't all that great, it's better than what I had. Overall, nothing that can't be handled.  Dare I say, it's sorta easy.
(http://i.imgur.com/tMKiN4l.jpg) (https://imgur.com/tMKiN4l)
(http://i.imgur.com/bsjz2Bv.jpg) (https://imgur.com/bsjz2Bv)
(http://i.imgur.com/Sw8ZcI9.jpg) (https://imgur.com/Sw8ZcI9)
(http://i.imgur.com/HySwWDk.jpg) (https://imgur.com/HySwWDk)
(http://i.imgur.com/X0Bn7ag.jpg) (https://imgur.com/X0Bn7ag)
(http://i.imgur.com/ITlq4Mb.jpg) (https://imgur.com/ITlq4Mb)
(http://i.imgur.com/fWtZgHc.jpg) (https://imgur.com/fWtZgHc)
(http://i.imgur.com/6KAmFQJ.jpg) (https://imgur.com/6KAmFQJ)
(http://i.imgur.com/J34S36G.jpg) (https://imgur.com/J34S36G)
(http://i.imgur.com/cViwii0.jpg) (https://imgur.com/cViwii0)
(http://i.imgur.com/XQqWDeZ.jpg) (https://imgur.com/XQqWDeZ)
(http://i.imgur.com/8NskoVR.jpg) (https://imgur.com/8NskoVR)
(http://i.imgur.com/dKxbxt3.jpg) (https://imgur.com/dKxbxt3)
Post by: Bill Boyle on November 25, 2017, 02:50:04 PM
I must commend you on your effort.  You've taken on a monumental project and inch by inch you're addressing each and every problem and solving it.  It takes a lot of discipline, aside from talent, to pursue such a project to the end.  I can see you're getting closer, my hats off to you.  Two thumbs up.  Very cool.   8-)
Post by: Jack on November 25, 2017, 03:58:11 PM
Very nice work, it's starting to look like a car again.
Post by: roadking77 on November 25, 2017, 06:31:21 PM
I like your quarter panel straightening jig!
Post by: Ford5of5 on May 12, 2018, 12:32:23 PM
This massive update is the culmination of 6 months work.   :shock: :mad: :lol:
(https://farm1.staticflickr.com/957/41161857985_50c42513fe_z.jpg) (https://flic.kr/p/25HkhjD)
(https://farm1.staticflickr.com/829/28189132048_c85e98e53e_k.jpg) (https://flic.kr/p/JWYES5)
(https://farm1.staticflickr.com/974/41161859575_032b6be4e5_z.jpg) (https://flic.kr/p/25HkhN4)
(https://farm1.staticflickr.com/975/28189135058_ad742dc9d0_k.jpg) (https://flic.kr/p/JWYFKY)
Post by: Ford5of5 on May 12, 2018, 12:40:44 PM
So, I've been too lazy or too busy to do anything to my car. I wasted the winter and did very little. On top of that, I spent way too much time agonizing over which product to use for the roof seam. I've read and read and asked opinions. In the end, I flipped a coin to decide between using All Metal or short hair.  All Metal won the flip.
Post by: Grand73Am on May 12, 2018, 09:44:53 PM
I think you made the right choice. I've used All Metal, and Metal-2-Metal to replace the lead in body seams in many Classic Chevys I restored over a 30 year period, and never had a problem with it.
Post by: 4wheeling79 on May 12, 2018, 11:57:02 PM
Good decision I have used both my self great products works every time glad to see you are back at it!
Post by: formula jg on June 04, 2018, 11:36:25 AM
Just catching up with this project and wanted to see how you've been progressing and must say I have not been disappointed. It must seem like it's taking forever but you are closer than you think, keep up the great work.
Post by: FormTA on June 04, 2018, 11:56:11 AM
I know we spoke but i don't remember what you decided but the repair came out great at that seam. Nice work. Now you can be proud again.  :D
